crx fuse box. What is this wire?
Old Oct 21, 2008 | 08:23 AM
almostjdmeg's Avatar
Default crx fuse box. What is this wire?
What is the big black wire next to the big red wire? Are these two connected? I relocated my battery, can i wir my battery to were the red wire is? and the starter to were the black wire is? Thanks
Old Oct 21, 2008 | 08:44 AM
harmonator84's Avatar
Default Re: crx fuse box. What is this wire? (almostjdmeg)
Without me looking at my car or doing any research, I am pretty sure that the red wire goes to your starter and to your battery. I think the black is a ground. Now I could be wrong...Im just going off of memory. I am sure someone can chim in and let you know 100 percent.
Old Oct 21, 2008 | 08:55 AM
sleepingciv's Avatar
Default Re: crx fuse box. What is this wire? (harmonator84)
i looked at my car and the red one does go to the battery then to the starter, as for the black one im not sure it runs into the harness. ??but im thinking altenator??
Old Oct 21, 2008 | 09:43 AM
Default Re: crx fuse box. What is this wire? (sleepingciv)
If the black one does run to the alternator can i run the battery wire were the red wire is, and then run a wire from the black wires position to the starter? Would that work? Thanks
Old Oct 21, 2008 | 09:47 AM
im not totaly sure if that black wire is to the alt or not, get a test light to make sure first.
if ya relocated your battery, why not run 2 wires from the battery . one to were the red wire is at and the other to the starter.
Old Oct 21, 2008 | 10:43 AM
Speed PHreak's Avatar
The "black" wire runs to the alternator. It's actually a white wire though, it just has black heat shrink on the terminal that hides the color.
Old Oct 21, 2008 | 02:04 PM
Lamchop0000's Avatar
Default Re: crx fuse box. What is this wire? (Speed PHreak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speed PHreak &raquo;</TD></TR><TR><TD CLASS="quote">The "black" wire runs to the alternator. It's actually a white wire though, it just has black heat shrink on the terminal that hides the color.</TD></TR></TABLE>
QFT
Old Oct 21, 2008 | 02:09 PM
Default Re: crx fuse box. What is this wire? (Lamchop0000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lamchop0000 &raquo;</TD></TR><TR><TD CLASS="quote">
QFT</TD></TR></TABLE>Whats QFT
Old Oct 21, 2008 | 02:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepingciv &raquo;</TD></TR><TR><TD CLASS="quote">Whats QFT</TD></TR></TABLE>
Yea I dont know either.
But he is right..i remember now...that is in fact a white wire!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by almostjdmeg &raquo;</TD></TR><TR><TD CLASS="quote">If the black one does run to the alternator can i run the battery wire were the red wire is, and then run a wire from the black wires position to the starter? Would that work? Thanks
I would think no. Why dont you just run your battery wire straight to the starter then just branch a wire off of that wire to the fuse panel..thats what i did.
Old Oct 21, 2008 | 03:05 PM
StayKrafty's Avatar
QTF= Quoted for truth
Old Oct 21, 2008 | 03:53 PM
Crx Jimmy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by harmonator84 &raquo;</TD></TR><TR><TD CLASS="quote">
Why dont you just run your battery wire straight to the starter then just branch a wire off of that wire to the fuse panel..thats what i did.</TD></TR></TABLE>
Thats what I did as well, run 4 gauge from the battery to the starter then you can use a 8gauge to the fuse box from the starter. the starter is what draws the most juice go direct to the battery
Old Oct 22, 2008 | 09:04 AM
Default Re: crx fuse box. What is this wire? (Crx Jimmy)
I tried it my way and it works perfect. Thanks for the help though.
Robert Williams
Apr 4, 2019 08:49 AM
4runner
Jun 9, 2005 11:38 PM
BodyKits NW
Aug 9, 2003 12:38 PM
ATS*Mark
Aug 5, 2003 01:33 PM
LuderX
Jan 13, 2003 05:49 PM
