Suspension & Brakes Theory, alignment, spring rates....
Piston Poped out?
Old Oct 20, 2008 | 10:37 PM
thanh4o8's Avatar
Default Piston Poped out?
I changed my brakes earlier and the piston feel out of the socket cause my dumbass friend was pumping the bakes for no freakin reason and it squired out all of the oil and the piston fell out. I press it back in and did the brake change and bleed the front two brakes. and replaced it. should i have to worry about fluid ceeping through the piston.
Old Oct 20, 2008 | 11:52 PM
_BEN_'s Avatar
Default Re: Piston Poped out? (thanh4o8)
If it leaks it leaks replace it. You will also have to replace the shoes too if they get soaked.
The slave cylinders are not that much. $25 oem
I probably would have just replaced it once it came apart. But if it's back together, working fine and not leaking I wold not worry about it.
Old Oct 22, 2008 | 10:08 AM
srmofo's Avatar
Default Re: Piston Poped out? (_BEN_)
I think he is talking about calipers? if so, did it tear the O ring around the piston? if you got it back and its not leaking then you are ok. but I doubt that it is not leaking unless the calipers were pretty new.
If its a wheel cylinder (rear brakes) the same applies.
slave cylinders are on hydro clutches
Old Oct 22, 2008 | 12:37 PM
_BEN_'s Avatar
Default Re: Piston Poped out? (srmofo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by srmofo &raquo;</TD></TR><TR><TD CLASS="quote">
slave cylinders are on hydro clutches </TD></TR></TABLE>
Your right. Wheel cylinder is the correct term.
Slave cylinder is not wrong either. By general definition a slave cylinder converts hydraulic pressure into mechanical motion.
&lt;-- Used to be an airframes and hydraulics mechanic (navy) so I still think in general terms. The nightmare I had to deal with on a regular basis. http://farm4.static.flickr.com...9.jpg j/k it was not that bad.
Modified by _BEN_ at 2:57 PM 10/22/2008
Old Oct 22, 2008 | 04:29 PM
srmofo's Avatar
I knew what you meant, but he may not of...and I could almost guarentee a parts house would of sold him a slave cyl for a brake job
Old Oct 22, 2008 | 10:59 PM
racebum's Avatar
depends on if the rubber tears like stated above. when you service multi piston calipers generally a buddy stomps the pedal to pop whichever piston you are trying to remove out. you then add new booties and press back in. i can't count how many of the PBR dual piston units i've rebuilt that way. track pads vaporize booties.
Old Oct 23, 2008 | 06:57 AM
Psychoteen101's Avatar
Also, if the piston fell on the floor, hope you inspected the piston for any damages...
Old Oct 23, 2008 | 10:36 PM
thanh4o8's Avatar
Default Re: Piston Poped out? (idrivesideways)
how are is it to replace the boot
Old Oct 24, 2008 | 12:26 PM
srmofo's Avatar
the boot is to just keep dust and dirt out of the caliper, if its not there then dirt will get into the cylinder of the caliper and cause scraches on the walls and then tear up the oring seals causing the caliper to leak fluid out and air in. honestly if its just a stock caliper, just replace it , they're not that expensive
Don Dempsey
Honda CR-V & Element
Jan 21, 2013 07:28 AM
tbuck23
Oct 14, 2012 04:59 PM
pos_cd5
Apr 21, 2006 08:34 AM
Aber
Mar 12, 2004 02:51 PM
DSayavan
Mar 3, 2003 07:15 AM
