crx rear disc conversion(trailing arm bushings)
Old Oct 20, 2008 | 07:23 PM
98integralsB18's Avatar
Default crx rear disc conversion(trailing arm bushings)
i have a 1990 crx with da rear trailing arms. i went to get it inspected and said i needed new bushings. i cam home the old ones basicly fell out. i was wonder what size i need do i have to burn the old one out or can i just buy the whole thing so ill i ahve to do is just press it back into the trailing arm i found 2 different sizes one is, 52385-SK7-N02 which is 3.352 inches. and the other one is 52385-SR3-000 it is 3.170 inches. which one to get i think its the bigger one but not sure. thanks.
Old Oct 21, 2008 | 06:19 AM
pxsx's Avatar
Default Re: crx rear disc conversion(trailing arm bushings) (98integralsB18)
dont get stock ones.
password jdm sells some sweet aluminum ones.
Old Oct 21, 2008 | 07:42 AM
red_EF9Si's Avatar
Just buy some aftermarket bushings and have a local machine shop press them in for you.
http://cgi.ebay.com/ebaymotors...ZWDVW
Old Oct 21, 2008 | 08:25 AM
CRX Toad's Avatar
Tell Acura what you have and they will get you the right ones. They are very easy to do I have done several of them on different cars.
If you are doing street driving just get stock or Mugen one, aluminum (spherical) will not give you the ride you desire.
DO NOT GET AN AFTERMARKET ONE.
Also if you are lowered make sure to clock it so that it won't wear as fast. As seen here http://www.performanceforum.co....html
Old Oct 21, 2008 | 12:31 PM
yea i bought liek aftermarket ones and i heard nothing but bad about them so im just gonna go oem on it and get the right ones. thanks
jacksonww
Oct 5, 2010 05:09 AM
ED9man
21
Jun 7, 2006 05:07 PM
mrtoastyjr
May 4, 2004 10:40 PM
Jdm93civic
Aug 15, 2003 05:35 AM
sleeperCRX
Sep 25, 2001 07:35 AM
