Transmission & Drivetrain Gearboxes, Differentials, Clutches
LSD Question
Old Oct 20, 2008 | 05:17 PM
rustydusty1717's Avatar
Default LSD Question
first off how much they cost for a good one and also is it NEEDED for a boosted civic putting down 300-325 whp? building top end of my b16 now for more boost and if i'm gonna have serious traction issues i'd like to know right away so i can install an LSD.
Old Oct 20, 2008 | 09:34 PM
Aquafina's Avatar
A GOOD one will be in the 650-9xx (whatever a Quaife is now) range.
Depends on what kind of driving you do. I have a massive guesstimated 115whp D16 and without an LSD, my car was worthless the last time I was on track (road course). Regardless, the kind of power you have warrants an LSD if for no other reason to save your trans from a blown stock diff.
Old Oct 21, 2008 | 01:18 PM
i'm gonna be pushing 300-320 whp. will i have a problem with traction if i don't have an LSD? i mean the tires are gonna spin a bit i understand but if i go to race someone i don't wanna be sitting at the light spinning while they're gone.
Old Oct 21, 2008 | 01:36 PM
Aquafina's Avatar
LSD will be a big help.
Old Oct 21, 2008 | 04:02 PM
how bad is traction gonna be at 300-320 whp without an LSD?
Old Oct 21, 2008 | 04:06 PM
Aquafina's Avatar
Couldn't tell you. Non existant on good street tires at 380whp with LSD, Y1 trans.
Old Oct 21, 2008 | 07:11 PM
is there any LSD's for about 500 or 550?
i don't do any track driving. just street and drag strip once in a while. like i've said my car's power is gonna be at 300-325 WHP estimate.
Old Oct 21, 2008 | 07:17 PM
Aquafina's Avatar
Not that I know of.
Old Oct 21, 2008 | 08:16 PM
anyone else running a similar setup as me without an lsd? like to get an actual answer or some info or anything.
Old Oct 21, 2008 | 10:39 PM
BrownDx's Avatar
Default Re: (Aquafina)
I'm waiting for an MFactory LSD.
They have them available right now for the b16's for $650.00.
I'd say you would be better off with one than without one.
That is my opinion with no experience with a 350whp car.
Old Oct 22, 2008 | 04:05 PM
how much power are you putting out brown?
Old Oct 22, 2008 | 06:24 PM
fcm's Avatar
fcm
Old Fart
Default Re: (rustydusty1717)
You will need an LSD and a good one, without one you will be busting axles or C/V joints.
I am running, [or was] about 225 HP, [nitrous oxide] and went through one axle and 3 C/V joints, [in two months] until I installed the GSR tranny with a PhantomGrip LSD and a set of Raxals, no problem since, my new motor, [boosted B18a] will put down 325BHP at the wheels, I will replace the GSR tranny with a modified LS tranny with a Quaife LSD, or if I can find a Type R tranny and not get raped buying it, I will use it.
The PhantomGrip sells for $500-$600, but get extra sets of springs as they are only good for about one year. 94
Old Oct 23, 2008 | 10:44 AM
on phantomgrips site it's saying $300 for an LSD. is that correct? does it require anything else or is all in that kit. also i've never done an LSD in any of my honda's and i'm not sure if phantom grip is good quality or shitty. everyone's saying $600+ for a good LSD so this price makes this very fishy.
Old Oct 23, 2008 | 11:34 AM
Mista Bone's Avatar
D Tranny Guru
"Phantom Slip, works so good you never know it's there"
JUNK!
Old Oct 23, 2008 | 11:38 AM
what's the best "bang for buck" lsd out there then? last thing i want is to build my car up and then have my tranny blow up. rather spend 600 for an LSD and not have to worry
Old Oct 23, 2008 | 12:36 PM
Aquafina's Avatar
MFactory. Better and more consistent clearances than the Quaife, lighter, stronger, cost less.
Old Oct 23, 2008 | 05:30 PM
turbo boost's Avatar
type r factory lsd
can be had for 3-400$
get a type r lsd and instal it in ur tranny
Old Oct 23, 2008 | 07:38 PM
BrownDx's Avatar
It'll be in a kinda stockish motor.
Just do it one time, and buy a good product.
Old Oct 23, 2008 | 08:35 PM
i'm gonna try without an lsd for now. install one later on if i need one.
Old Oct 24, 2008 | 12:24 AM
civickiller's Avatar
how come nobody said obx
340whp with my friends sohc on 24.5 slicks
161 whp lsvtec mine and before i got it, b16 crx going 12.80's
held up fine so far
Old Oct 24, 2008 | 06:00 AM
fcm's Avatar
fcm
Old Fart
Yea, probably $300 US, the PhantomGrip is a pretty basic "LSD" and as I said, get extra springs, I have had mine in a GSR tranny, [94LS] for more then 10 years without any problems, [other then the springs] but will be replacing it with a "real" LSD in my [LS tranny] or a Type R tranny for the new motor.
I got the P/G for free from a shop that had just picked up PhantomGrip as a line and wanted to try it out, I had the GSR tranny pulled apart to inspect it before I installed it so we put it in, I was pretty sceptical that twp blocks of metal with four springs in-between would work, but was satisfied it worked after a few wins at the autocross track, and no more busted axles or C/V joints. 94
Old Oct 24, 2008 | 09:04 PM
Default Re: (fcm)
get a obx for $400 and dont gotta worry except for taking it apart and making sure everything is good
Old Oct 24, 2008 | 09:08 PM
i'm gonna try without an LSD for now. i know how to pull motor very easily now so if i decide i need an LSD i could pull motor and installed the LSD and have motor back in probabally in one day. but atleast now i know what to get. thanks guys
Old Oct 24, 2008 | 09:33 PM
Aquafina's Avatar
You don't pull the engine with the trans. Can't install LSD in one day unless you have all diff shims in stock, or get lucky and don't need a different shim.
Old Oct 24, 2008 | 09:36 PM
Mista Bone's Avatar
D Tranny Guru
3 hours to install a OBX in a D-series if the tranny is healthy and no issues
I haz shims
