need help tried everything d16z6 starts runs like crap dies and code 14 *SEARCHED
ok guys so heres my dehlima
car is an 89 dx hatch with a d16z6 in it
obd0-obd1 jumper with chipped p28
the car will start and runs horribly then if you dont give it gas it'll soon after die
and im throwing code 14 idle air control valve
ok so heres what i have tried so far
-new iacv
-new plug
-new timing belt
-new alt belt
-tried a stock p30 with the same results
-bypassed the jumper harness with two wires coming straight from the iacv plug to the ecu plug..a9 and a23(is this right?)
-tried a5 and a23 cuz the chilton mauel i have(87-95 civc,crx,dell sol) said that a5 was for the iacv.
-flushed the coolant system many times
- and i have reset the ecu every time...
so im am stumped on whats going on...nothing is making a difference
could my motor just all the sudden be bunk?
any suggestions would be much appriciated
-new iacv
-new plug
-new timing belt
-new alt belt
ya thats the idle air control valve..is that what your talking about?
and no i havnt change the map..but im pretty sure it would throw a code if the map sensor was tweaked
i also change the tps awhile back but kinda just turned it to one side and put it on...could this be the cause of my problems?
IM guessing that if this has been happening since u installed the swap, and only if its been occuring since the swap, that you are using the original distributor that came with the car. I had a problem like this on my first swap. If you are using the original distributor swap it out with the one for the engine you are using. Its a long shot but it COULD be your problem.
Like accordaffair said check the idle via the screw.....also check for vacuum leaks...this can cause your car to idle and or drive horrible and could explain why you have to compensate by giving it gas which is really just opening the throttle and giving it more air to compensate for the vacuum that you are losing.....hope that helps dude
hey guys sorry i dont have the web right now
i checked for air leaks and didnt find any
also this hasnt gone on all the time the swap has been in just started one day cel came on and its been code 14 since...
and what is the idle air screw you guys are talking about?
does anyone have a helms picture where it is?
and the iacv was from a jinkyard...is there any way to test it?
and thanks for all the feedback guys keep it commin
so i dont know what i did but now the car idles good but when i try to rev it it falls flat on its face but if i slowly press the gas then it dosnt
still throwing code 14
the idle screw is on the top of the throttle body
IACV testing (this is for a d16a6) use an ohmeter between the leads, should be 8-15 ohms, if yes, check for continuity to ground between each lead, if no, turn the ignition switch in and measure for battery voltage between the leads
theres more to it but try those and also connect the leads to battery voltage directly and the valve should click.
Check here for more
http://media.honda.co.uk/car/o...7.pdf
Check here for more
wow thats awesome info thanks alot bro!!
anyone have this kind of chart for a z6?
so what do i do with the idle screw? just play around with it till it idles better
Ghett0_ed
Oct 25, 2008 05:22 PM
SlaMMedB16
Jun 12, 2008 11:55 AM
1991civicd16z6
13
Jan 20, 2008 09:43 AM
