ATTN. Anyone with Golden Eagle Mfg. block!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jul 29, 2002 | 09:14 AM
X-Mazda 3 Racer's Avatar
Default ATTN. Anyone with Golden Eagle Mfg. block!!!!!!!!!!!!!!!!!!!!!!!!!!!
There is something we changed in our policy and I will explain why. We have finally found something that will prevent the sleeves from rusting, so this is what you should do:
Every block should have "Bar's Leaks Radiator Stop Leak and Conditioner" added to the coolant. This product has shown to be a very big asset to our blocks. Not only does it keep the sleeves from rusting, but it also conditions the water pump and prevents water seepage from the sleeves to the oil chamber. We strongly suggest using this in your blocks, or anyone you kow that has a block or ours, or anyone that has a sleeved block from someone else. You can get this product from any auto store for about $3.00. Just add it to your coolant and follow the directions on the bottle. You only need to purchase the 5.5 oz. bottle for your Honda/Acura motor. Part number is either C16 for the 10 fl. oz. bottle or R6 for the 5.5 fl. oz. bottle. Check it out at http://www.barsleaks.com/ Remember, we only back Bar's Leaks as the product to use, do not use anything else!!!!! If you have any questions, please feel free to let me know. Thanks for your time.
[Modified by V8KILR, 6:36 PM 7/29/2002]
Old Jul 29, 2002 | 09:28 AM
VTC_CiViC's Avatar
Default Re: ATTN. Anyone with Golden Eagle Mfg. block!!!!!!!!!!!!!!!!!!!!!!!!!!! (V8KILR)
GE blocks are rusting!?
Old Jul 29, 2002 | 09:31 AM
Default Re: ATTN. Anyone with Golden Eagle Mfg. block!!!!!!!!!!!!!!!!!!!!!!!!!!! (VTC_CiViC)
Every sleeved block rusts, no matter who it is from. The rust does not pose a problem at all, it is just the nature of the ductile iron to rust easily. I just like to have it as perfect as possible. So as there have been no complaints of this happening, I want to keep it that way and make it better for everyone. Just a little heads-up is all!!!
Old Jul 29, 2002 | 09:38 AM
Mikey3000's Avatar
i guess this is only for open deck blocks right?
Old Jul 29, 2002 | 09:46 AM
Default Re: ATTN. Anyone with Golden Eagle Mfg. block!!!!!!!!!!!!!!!!!!!!!!!!!!! (Salvatore Leone)
Actually, it is for all types of blocks. You see, the three major manufacturers, General Motors Corp., Ford Motor Co. and DaimlerChrysler all add this stuff to their cars before they hit the sale lot. It is just a good preventative measure to ensure there are no problems later on. Remember, This is not a problem. I am just making sure it doesn't become one!!!!!!
C-speed's Avatar
No wondering the coolant always comes out brown...
Thanks for the tip.
Old Jul 29, 2002 | 09:47 AM
kidkutz's Avatar
iron sleeved closed deck blocks don't apply?
Old Jul 29, 2002 | 10:19 AM
vtecvoodoo's Avatar
Future Texas Boy
Done. Thanks for the heads-up, Vince.
Ryan
Old Jul 29, 2002 | 10:32 AM
b18bturbo's Avatar
Default Re: ATTN. Anyone with Golden Eagle Mfg. block!!!!!!!!!!!!!!!!!!!!!!!!!!! (vtecvoodoo)
did that along time ago vince.. should have told you that... this happens even to the darton sleeves...
Old Jul 29, 2002 | 10:34 AM
justagsr's Avatar
Default Re: ATTN. Anyone with Golden Eagle Mfg. block!!!!!!!!!!!!!!!!!!!!!!!!!!! (b18bturbo)
going to the automotive store right now...seriously. I still need my block back from Vince though.
Old Jul 29, 2002 | 10:54 AM
2K_TEG's Avatar
going to get some now. TTT for those who haven't seen this.
Old Jul 29, 2002 | 10:55 AM
00ITR #543's Avatar
I use Red Line water wetter in my radiator. Is that compatible with the Bar's Leak???
Old Jul 29, 2002 | 10:58 AM
b18bturbo's Avatar
Default Re: ATTN. Anyone with Golden Eagle Mfg. block!!!!!!!!!!!!!!!!!!!!!!!!!!! (00ITR #543)
its different. The bars leak is a conditioner and rust preventive addative.
Old Jul 29, 2002 | 11:17 AM
boostaholic's Avatar
So that's why the outside of my iron sleeves were a little rusty when i tore down the motor Good tip
Old Jul 29, 2002 | 11:44 AM
Mikey3000's Avatar
cool. i'll be sure to purchase some.
Old Jul 29, 2002 | 12:38 PM
Default Re: ATTN. Anyone with Golden Eagle Mfg. block!!!!!!!!!!!!!!!!!!!!!!!!!!! (kidkutz)
Like I said before, this should be done on ALL aftermarket sleeved blocks ( From any one like Golden Eagle Mfg, RS, Benson's, A.E.B.S., Darton, etc. ) I just don't want anyone to see some rust and say that sleeving a block sucks. Although it takes a little more maintanence, sleeved blocks can be just as reliable as stock if the proper precautions are taken. Adding Bar's Leaks is one of the precautions. Just to make life a little easier for everyone!!!!!
Old Jul 29, 2002 | 12:40 PM
Yes, Bar's Leaks is compatible with Water Wetter. Although Water Wetter helps to prevent rusting also, I still suggest some Bar's Leaks!!!! Like I said, Please let anyone know who has a sleeved Golden Eagle Mfg. block that this is what to use. It is a must!!!! Thanks all!!!
[Modified by V8KILR, 9:41 PM 7/29/2002]
Old Jul 29, 2002 | 12:55 PM
VTC_CiViC's Avatar
Hey Vince, get off the computer and finish my block!!!
Heh j/k, I want my sleeved/bored D16 back dammit!
Old Jul 29, 2002 | 01:13 PM
Are you in the Gilstrap buy?
Old Jul 29, 2002 | 01:38 PM
2K_TEG's Avatar
Vince,
Just wanted to stop and let you know your **** is madtite y0!
Seriously though, my block looks great and I got it back in a very reasonable amount of time. Now I just have to put it back together.
Thanks.
Old Jul 29, 2002 | 01:45 PM
Default Re: ATTN. Anyone with Golden Eagle Mfg. block!!!!!!!!!!!!!!!!!!!!!!!!!!! (2K_TEG)
Thanks for the compliment. I like to hear it. Like with all my customers, please let me know how everything goes. If you ever have a problem with the block, don't hesitate to call me. (909) 592 - 4311. Thanks again. By the way, Don't forget the Bar's Leaks!!!!!!!!!
[Modified by V8KILR, 10:55 PM 7/29/2002]
Old Jul 29, 2002 | 01:54 PM
KCHybrid's Avatar
Should you add the Bar Leaks every time you flush and refill the colant system? or is tihs a one time thing?
Old Jul 29, 2002 | 01:56 PM
Default Re: ATTN. Anyone with Golden Eagle Mfg. block!!!!!!!!!!!!!!!!!!!!!!!!!!! (KCHybrid)
Use it everytime you flush and re-fill. For about $3.00, it is great piece of mind!!!
Old Jul 29, 2002 | 01:59 PM
VTC_CiViC's Avatar
Yessir I am
77mm bored D16
Old Jul 29, 2002 | 02:30 PM
My computer shows you are still being worked on out in the back. Your block must have come in on the second wave of the Gilstrap blocks. It should ship this week. Call for the tracking number!!! (909) 592 - 4311
