Nitrous Express "N-ter cooler kit" ???
I'm a little curious if anybody on here has tried this or read anything about it.
From what they say, it seems like a pretty safe way to get a little nitrous boost?
Any comments???
[Modified by vadeR, 6:01 PM 7/29/2002]
Any comments???
yes, i am also interested in this kit..any input would be real nice...
TTT
(i just bought a new NX kit for 50$!!!!!!!!with the bottle full!!!!)
TTT
IT just chills the intercooler, it doesn't inject nitrous into the engine. It wouls be easier to just have a nitrous setup w/ the purge selonoid directed at the intercooler. A 20 or 35 shot on a F/I engine is enough to lower the intake temps. That way you get the benfits from both the "N-ter cooler" and having 75% of a nitrous set-up why just go ahead and add it in?
[Modified by Speed PHreak, 6:23 PM 7/29/2002]
Thanks for the info Speek Phreak.
I'm more curious on how much HP it will produce. They claim it made 58hp on a turbocharged honda but they don't state which one.
Does anybody on there have this kit and Dyno'd it?
anyone else??? what if i just sprayed no2 inside od the intercooler?? would this cause a really lean condition??or would it just cool the charge big time??
brian
TTT
brian
TTT
There's currently a contest on their website. If you can come up with a name that they like for the thing, you'll win a free kit. Hmm what would be a good name...
I'd like to know this to because I am running extremly rich so I was thinking I should throw some N2O into the intercooler or the charge pipe to lean it out. Dumb idea or not?
well, i just hooked mine all up,a nd i am now spraying a 35-40 shot into my charge pipe,i talked with brian @NX and he told me that i will be ok because i am adding fuel while i add nitrous, so going lean shouldnt be a prob. the only precaution he gave me was to make sure that i am no closer to the throttle body than 12inches, on a turboed motor.
thanks
brian
p.s. a 35-40 shot a a boosted motor kicks ***.!!!!! when it hits while i am under a full 15-16 psi pull in third gear the tires just friggin start spinning uncontrollably...
HTH
thanks
brian
HTH
Turbodcx, could you post some pics of your N-ter cooler kit setup ( especially of your intercooler )? Just want to see what it looks like on a turbo car. Thanks.
slowcivic, i am not using the n-tercooler, i am simply just hooking up the nitrous you you would nomally,except that i am 12in away from the throttle body... i am just sprying a 35-40 shot into the charge pipe just after the BOV.
HTH
brian
HTH
brian
I dont see why you would stay 12 inches away? i mean a wet shot would be after the throttle body so why does it matter what distance it is from the throttle body?
ok, first off i am using a wet shot,which sprays fuel and nitrous onto the intake....
i was told to keep it 12inches away from the TB because of fuel and nitrous atomization that needs to happen on a turboed car.. (this came sraight from NX)
Brian
Brian
Guest
Posts: n/a
HOLY ****...... i didn't realize that someone actually made a kit that did that, i just thought that peopla had fabricated their own systems to spray an intercooler. with the extra money i'm gonna have i think i'll buy one of those
TurbodCX, what's up man. Do you have pics of your car and set-up. Sounds like you have a great car. . . Would like to see more. . .
Jeramy
Jeramy
Jeramy
Jeramy
Accord94DX
Apr 7, 2003 03:44 AM
