Accord 2000 Climate Comtrol Unit
Hi My Climate Control Unit stop working, I check all the fuse, I take out the Control, but my question is How I can test via Cable join if is the control unit, I check with tester in the port and some cable have positive.
I want to jump some cable to be sure that is the control.
Thanks.
Thanks.
We need to know the static pressures of the Air conditioning OR, are you saying that you have no light when you turn on the AC and the fan or that absolutely nothing works, no power light, no fan for the heat, nothing???
You're right, when I turn on the fan I can hear and feel the air thru the holes, but the other controls and lights are off including the defrost to the back.
