Turn Signal Problem on 88 Hatch
Old Oct 19, 2008 | 06:11 PM
I LUV MY EJ1's Avatar
Default Turn Signal Problem on 88 Hatch
so i got this ef with cut wire where the corner light n bumper light go so i got other one from the junkyard n i hook them up to see if they work but they didnt and i already
Modified by I LUV MY EJ1 at 8:01 PM 10/21/2008
Old Oct 19, 2008 | 08:20 PM
ryanevansoh's Avatar
Default Re: NEED HELP WITH MY 88 EF HATCH (I LUV MY EJ1)
i have no idea what the hell u are even saying
Old Oct 19, 2008 | 11:28 PM
tunerkid7's Avatar
Default Re: NEED HELP WITH MY 88 EF HATCH (ryanevansoh)
haha what the hell
Old Oct 20, 2008 | 12:08 AM
My_EFsedan's Avatar
type in non-cap locks dude. type full letters as well (who still does that typing in short cuts in words?)
is it the turn signal on the corner light or the bumper? or is it the rear?
make sure its pos/pos and neg/neg. and check the fuses for it under the steering column.
Old Oct 20, 2008 | 04:28 PM
Default Re: NEED HELP WITH MY 88 EF HATCH (My_EFsedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by My_EFsedan &raquo;</TD></TR><TR><TD CLASS="quote">type in non-cap locks dude. type full letters as well (who still does that typing in short cuts in words?)
make sure its pos/pos and neg/neg. and check the fuses for it under the steering column.</TD></TR></TABLE>both corner n bumper
Old Oct 20, 2008 | 07:40 PM
Alex_C's Avatar
the bulbs in the ones you got from the wrecker might be fried. I'd say check that first, then check to see if the wires going to them are getting power. If not, work your way back to the problem - it shouldn't be too hard. If you need a wiring diagram, there are plenty of places on the net that have the EF service manual free to download. Google "EF civic service manual". Hope this helps.
Old Oct 21, 2008 | 09:07 AM
jdmed3's Avatar
Default Re: NEED HELP WITH MY 88 EF HATCH (Alex_C)
Get it fixed?
Old Oct 21, 2008 | 11:43 AM
PISTONEMPIRE's Avatar
Just get a tester to see if the wires are getting any power....you could just go behind the cluster and set the turn signal and check each wire to see which one is blinking on and off ( the tester bulb should be going on and off) then just cut and slpice wires and connectors all the way to the lights. This is a last resort if cannot find the problem or don't want to dish out the bucks to a electrician. but it does work just tie everything up and wrap in electrical tape real neat and tuck all wires. just a suggestion..........it could just be that your wires are fried.
Old Oct 21, 2008 | 07:00 PM
Default Re: (PISTONEMPIRE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Alex_C &raquo;</TD></TR><TR><TD CLASS="quote">the bulbs in the ones you got from the wrecker might be fried. I'd say check that first, then check to see if the wires going to them are getting power. If not, work your way back to the problem - it shouldn't be too hard. If you need a wiring diagram, there are plenty of places on the net that have the EF service manual free to download. Google "EF civic service manual". Hope this helps.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PISTONEMPIRE &raquo;</TD></TR><TR><TD CLASS="quote">Just get a tester to see if the wires are getting any power....you could just go behind the cluster and set the turn signal and check each wire to see which one is blinking on and off ( the tester bulb should be going on and off) then just cut and slpice wires and connectors all the way to the lights. This is a last resort if cannot find the problem or don't want to dish out the bucks to a electrician. but it does work just tie everything up and wrap in electrical tape real neat and tuck all wires. just a suggestion..........it could just be that your wires are fried.</TD></TR></TABLE>
ILL TRY DIZ 2MORROW HOPEFULLY IT WORK THANKS
Old Oct 26, 2008 | 06:56 PM
Alex_C's Avatar
Default Re: (I LUV MY EJ1)
less caps please
jdm89crxhf
Nov 5, 2011 08:38 AM
joelreyes001
10
Oct 30, 2010 06:59 AM
B16CRXVTEC
Lighting
Mar 5, 2010 05:41 AM
CrazyModGSR
May 10, 2004 10:32 PM
1.8Tities
18
Apr 21, 2002 11:12 AM
