Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
lowering question ...
Old Oct 18, 2008 | 04:38 PM
p3terson17's Avatar
Default lowering question ...
i want to lower my 08 si sedan but i was wondering can i drop just the front and leave the back stock iam fine with the stock drop i just want the front a litlle lower
whats a good drop for the front ???
Old Oct 18, 2008 | 04:49 PM
-Gambit-'s Avatar
Default Re: lowering question ... (p3terson17)
why would you just want the front low? you could just get a set of springs and install only the fronts.
and theres always coilovers, you can adjust the height to how ever you want it.
Old Oct 18, 2008 | 04:52 PM
sixonethree's Avatar
or you could just install a set of comptech springs or eibach pro kits. they leave the front slightly lower than the back.
Old Oct 19, 2008 | 03:35 PM
p3terson17's Avatar
Default Re: lowering question ... (sixonethree)
but will i have a problem later on if i just change the springs in the front ????
Old Oct 19, 2008 | 04:35 PM
MiX's Avatar
MiX
your car would handle weird.
and yes your front shocks would wear faster.
Old Oct 21, 2008 | 07:00 AM
gg emerican's Avatar
Default Re: lowering question ... (MiX)
Why not just lower both?
A: it will look better if the rear and front are lowered.
B: Your car will handle better with both being the same.
C: You will have uneven wear on your struts, and probally tires depending on if you need an alignment
xluigix47
Suspension & Brakes
Apr 17, 2013 07:01 PM
timmy0tool
Apr 7, 2004 05:03 AM
binkster
12
Jan 26, 2003 05:13 PM
dubxl152
11
Dec 17, 2002 05:18 AM
dust1
Apr 27, 2002 01:58 PM
