Need a little help, please.
Old Oct 18, 2008 | 04:31 PM
Monkeyz1's Avatar
Default Need a little help, please.
Alright so I just finished my DPFI-MPFI, car runs, no limp mode, no CEL. However, i did adjust the tps a bit because i was having a slight acceleration problem. Now, when accelerating, the car will stagger before it gets over 2k, UNLESS i press the throttle ever so slightly to ease up the RPMs. If i push the pedal, not extremely hard, but a decent push, it staggers a bit but not when easing into it. I have a '89 Civic STD hatch, mpfi, CAI, full exhaust...blah blah. Would it be the TPS still? or is there something else? Timing, dizzy? anything please help.
Old Oct 18, 2008 | 04:50 PM
IndySporty's Avatar
Default Re: Need a little help, please. (Monkeyz1)
Go ahead and check the voltage on your TPS with the switch on but not running. It should move smoothly from ~0.5v up to ~4.5v at full open throttle. If it spikes anywhere you should try another one. Otherwise I'd say maybe anomalies in the MAP or o2 sensor.
Old Oct 18, 2008 | 04:56 PM
Monkeyz1's Avatar
Default Re: Need a little help, please. (IndySporty)
alright ill check out the tps. thanks.
FreshLude420
Mar 30, 2013 02:26 AM
turbob16ef
Mar 13, 2006 12:58 PM
SpoonEk253
Sep 26, 2005 11:37 AM
TeknikDC2
Mar 6, 2005 06:30 PM
stizzit
Jan 24, 2002 08:30 AM
