need help asap
Old Mar 13, 2006 | 12:07 PM
turbob16ef's Avatar
From: if you build it they will come, the bottom carolina, duh
Default need help asap
i have a ls that was in my integra and i threw like 7 different codes, so i thought it was just the computer, (is now bad), so couple months go by and i started to swap the engine into my crx, and now it is still doing the same thing, it starts it is just really ruff, idles good, just bogs every tiime i give it some gas, it has new dizzy, iac, and the sensor under the throttle body for the cold start, i have different injectors in as well and it is still doing the samething, also check the timing, also good, have a chipped pm6 for tuning.
does anyone have an idea of what could be the problem
thanks for the help
Old Mar 13, 2006 | 12:22 PM
.brian.'s Avatar
Default Re: need help asap (turbob16EF)
start out by finding what codes you are throwing.
https://honda-tech.com/zerothread?id=978933
Old Mar 13, 2006 | 12:58 PM
turbob16ef's Avatar
Default Re: need help asap (.brian.)
it is in a different car now, not throwing any codes, but the codes were iac, map sensor, #1 cylinder position, tdc, o2, throttle angle, ignition output signal
Monkeyz1
Oct 18, 2008 04:56 PM
turbob16ef
Mar 13, 2006 04:50 PM
mark_is_gay
Jun 15, 2005 04:23 PM
stizzit
Jan 24, 2002 08:30 AM
