New Axles, Acceleration Vibration
Old Oct 18, 2008 | 12:38 PM
SwissChEz82's Avatar
Default New Axles, Acceleration Vibration
I just replaced the axles on my 90 CRX with B16B engine. I used all the exact same methods for replacing as I did with my 91 CRX with DOHC ZC(obviously different axles though). On my first test drive I notice a slight vibration in second and third gear under acceleration that I had never felt prior to axle replacement. Any insight???
Old Oct 18, 2008 | 04:47 PM
Crx Jimmy's Avatar
Default Re: New Axles, Acceleration Vibration (SwissChEz82)
the new axle is junk,return it and get another
Old Oct 18, 2008 | 08:25 PM
Default Re: New Axles, Acceleration Vibration (Crx Jimmy)
I was hoping that wasn't the case. I purposely bought brand new axles too. I was also curious if its possible to over-tighten the axle nut because I didn't have a torque wrench.
Old Oct 19, 2008 | 12:37 AM
traxxasx's Avatar
Let me guess, autozone axles?
Lmao im in the same boat, thing is i said [freak] it, got used to the vibration, i took the axle off 20 times, and changed it with 4 different one, it got better, but still there.
Its the cheap *** REMAN axles from vatozone.
THEY [freak]ING SUCK!
My never vibrated, just changed it cause i had a ripped boot and my friend could get me the new one free, well a load of hell and stress came from these crap axles.
i used every autozone axle in town and they will not order a new one, cause they say i have a new one, yea a REMAN one, [freak]in idiots and there **** axles....
Good luck, you have to get lucky to get a straight axle.
Vibration under acceleration is always a bad inner cv joint.
No you cant overtighten the nut.
Its the axle trust me, its only started after the axle was changed.
Old Oct 19, 2008 | 06:00 AM
elmalouno's Avatar
Default Re: (traxxasx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by traxxasx &raquo;</TD></TR><TR><TD CLASS="quote">
thats about right for a free axle.
OP, what car did you buy the axles for?
Old Oct 19, 2008 | 07:35 AM
Default Re: (elmalouno)
I've never had a problem with Autozone axles&lt;&lt;knock on wood&gt;&gt;, I ran them on my stock engine and I've had them on my DOHC ZC for 4 years without a problem. I actually got these ones from Kragen and I even purposely bought the new axles as opposed to re-manufactured.
Old Oct 19, 2008 | 07:37 AM
Default Re: (SwissChEz82)
I bought axles from a 97 Del Sol VTEC. Matched up perfectly to the axles I took off.
Old Oct 19, 2008 | 08:33 AM
shortyz21's Avatar
to change 1 axle should not take more then 30 min if u know what your doing.
airtools help to.
Old Oct 19, 2008 | 07:42 PM
Default Re: (shortyz21)
Yeah, I just dont want to do it again. Anywho, have you ever heard of a break-in period for axles? The vibration seems to be subsiding.
Old Oct 19, 2008 | 07:51 PM
e30FTMFW's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by traxxasx &raquo;</TD></TR><TR><TD CLASS="quote">Let me guess, autozone axles?
Its the axle trust me, its only started after the axle was changed.</TD></TR></TABLE>
i was having this prob too man....turns out they were giving me a drivers axle for the pass and they are different...so it blew within hours every time
Old Nov 21, 2008 | 11:44 AM
driveslow's Avatar
Did you ever find a fix
BLU CIVIC
15
Sep 15, 2009 12:08 PM
Fly1865
Sep 24, 2006 05:29 PM
prostreetonline
Jul 7, 2006 04:13 PM
Teglessb18
Suspension & Brakes
Apr 4, 2006 12:58 PM
jdmskin
Oct 13, 2003 01:04 PM
