Recognizing Lean Burn in '97 HX w/5-spd?
Old Oct 18, 2008 | 05:06 AM
brucepick's Avatar
Default Recognizing Lean Burn in '97 HX w/5-spd?
'97 Civic HX w/5-spd.
How do I keep it in lean burn the maximum amount of time?
What conditions make it go into/out of lean burn?
Someone said that non-US versions had an indicator for lean burn but I haven't found how to hook up to that circuit.
Comments?
Old Oct 18, 2008 | 05:21 AM
BryanM.'s Avatar
Resident Gearhead
Default Re: Recognizing Lean Burn in '97 HX w/5-spd? (brucepick)
I can only guess that the HX's wideband primary 02 sensor has something to do with what your are asking about.
Old Oct 18, 2008 | 10:08 AM
Kista20's Avatar
keep the rpm's low for best economy, the shift light is designed for that.
Old Oct 18, 2008 | 08:22 PM
Kista20's Avatar
you can also get an aftermarket air/fuel gauge and wire it in, I'm not sure which wire it is but you can tap into it directly at the ecu.
kstampy
12
May 27, 2009 03:27 PM
Reece
29
Oct 19, 2004 06:22 AM
