transmission fluid???? help
Old Jul 29, 2002 | 04:37 AM
honda8882's Avatar
Default transmission fluid???? help
when i had my swap done a few months ago, the mechanic told me to bring him motor oil for the tranny fluid. it sounded wierd but i looked around and i found that to be ok. i just started havin tranny problems and someone told me that u only supposed to do that with 5 speed and i have auto. is my tranny messed up because of that??
Old Jul 29, 2002 | 04:52 AM
YeuEmMaiMai's Avatar
Default Re: transmission fluid???? help (honda8882)
your mechanic has **** for brains if he put engine oil for an auto tranny
honda ATF is what you need to use
if there is engine oil in your tranny you are gonna need a rebuild
Old Jul 29, 2002 | 04:57 AM
jweller's Avatar
Default Re: transmission fluid???? help (YeuEmMaiMai)
werd
Actually there is Honda MTF that you should be using for a 5 speed as well.
Old Jul 29, 2002 | 05:38 AM
Gennady's Avatar
New User
Makes sure you give him the bill for your tranny rebuild.
Flush the oil out ASAP and replace with Honda ATF.
Old Jul 29, 2002 | 05:47 AM
honda8882's Avatar
Default Re: transmission fluid???? help (Wont be beat)
its slipping now in high 2nd gear. if i flush it out, do u think it will be fine or do i definately need rebuild at this point
Old Jul 29, 2002 | 09:17 AM
Default Re: transmission fluid???? help (jweller)
yes he needs honda atf after a rebuild
Old Jul 29, 2002 | 10:04 AM
Big James's Avatar
New User
You need a rebuild. Once you start slipping, it is only going to get worse. The mechanic you used ain't too smart.
Old Jul 29, 2002 | 11:41 AM
Gennady's Avatar
New User
Default Re: transmission fluid???? help (Big James)
Cheapest rebuild is $1000. Make sure he pays, not you. Or make that shop rebuild it if they can.
Old Jul 29, 2002 | 12:12 PM
i would take it to honda and make the shop pay for the repair bill
Johnny_Rocket
Oct 8, 2005 04:34 AM
JDM Like Whoa
May 28, 2004 11:47 AM
cam0693
Aug 28, 2002 09:16 AM
AutoXsi2000
Mar 8, 2002 10:37 PM
EleanoR
Dec 13, 2001 07:54 AM
