DOHC ZC oil pan
So I have a zc in my 89 si and it was previously boosted and the oil pan is taped for an oil feed.
I just want to know if the oil pan from a brown top off a 1st gen 'teg will bolt up? Or if any other oil pan bolts up?
thnx
thnx
http://www.thezcr.com/forums/s...12262
There is a pdf file with just about all the info on the zc you could need.
Heres another one with some other info as well.
http://www.d-series.org/forums...91053
Happy zcing.
Happy zcing.
D16a6 pan will fit, not the same ,isnt as deep,.. But with the the oil return that is in ur oil pan. get a fitting of some sort or a cap if there is a fitting already in the oil pan..... maybe u will want to boost one day ,reuse it .
the 88-91 D16A6 oil pan is the one you need - the DOHC ZC uses the same oil pump and pickup as the D16A6 - the 86-89 Integra D16A1 has a different oil pump pickup and the pan won't work without also changing the pickup - the DOHC ZC pan is essentially the same as the D16A6, except slightly deeper and holds 1/2 quart more oil
Modified by jlicrx at 12:43 PM 10/18/2008
iplaybass
Jan 22, 2004 09:14 PM
