OIL PAN HELP FOR ZC MOTOR
k i have a zc motor SOHC and i need to change the oil pan because mine has a hole on the front it was turbo tapd adn well my ? is what other oil pan will work? will a D16 oil pan work?
Re: OIL PAN HELP FOR ZC MOTOR (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote">D16A6 oil pan FTW.
Thank you, please come again.</TD></TR></TABLE>lol
Re: OIL PAN HELP FOR ZC MOTOR (Got_soy)
good grief, dont confuse the guy.
how many times does this have to be covered?
THE SOHC ZC IS THE SAME DAMN THING AS THE A6 FOR CRYING OUT LOUD!
ok, off rant now.
ok, off rant now.
Re: OIL PAN HELP FOR ZC MOTOR (blaze_32001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blaze_32001 »</TD></TR><TR><TD CLASS="quote">which oil pan is larger the zc or the a6</TD></TR></TABLE>
Neither. I beleive they have the same Part Number.
Use the A6, it's the factory replacement.
The ZC gets it's extra power from slightly better CR and a wilder cam.
i was looking for an oil pan for when i had a zc... i had a bunch of b2's and a6's engines laying around. so I called up the local part stores to compare part numbers between the a1 and the b2
different part number but the gasket part numbers were the same. So I just assumed the oil drain plug were in different spots so the part #'s are different.
I never got around to it. I sold the zc hatch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got_soy »</TD></TR><TR><TD CLASS="quote">you must not of gotten the memo, the oil pan ias slightly larger which gives the zc 12 hp over the a6 </TD></TR></TABLE>
please explain how a larger oil pan makes 12 hp
the zc has a bigger cam and better flowing exhaust manifold
Re: OIL PAN HELP FOR ZC MOTOR (ludesrv)
The d16a6 oil pan is deaper. in order to use a a6 pan on a zc you need to use the pick-up tube off the a6 because it is longer.
the same goes for a d15 pan... it also is deaper.
Re: OIL PAN HELP FOR ZC MOTOR (jayjay)
https://honda-tech.com/zerothread?id=1684731
Make a few threads and your question may be answered.
FWIW, the pickup/oil pan is the same part number between the D16A6 (Si) and a D15B1/B2 (STD, DX).
Re: OIL PAN HELP FOR ZC MOTOR (civic-8442-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic-8442- »</TD></TR><TR><TD CLASS="quote"> i need to change the oil pan because mine has a hole on the front it was turbo tapd </TD></TR></TABLE>you know you can always just put a cap on it (and a hose clamp if your worried) thats what i did when i took the turbo off my zc for a weekend, had no problems
