crx b16 won't even crank
Old Oct 17, 2008 | 03:42 PM
KCRX's Avatar
Default crx b16 won't even crank
Replaced Head gasket. Now Ill put the key in and power comes on and seems normal. Try to start and it does nothing, like when you don't push the clutch in. Have the switch hardwired and checked it. Tried to jump, push start, battery is fine, swear I checked all connection twice. Fuel pump is priming. Any chance of some help would be so appreciated. I looked through the search engine and went through 60 of them and found nothing, so thanks in advanced
Old Oct 17, 2008 | 03:54 PM
Ldo's Avatar
Ldo
Default Re: crx b16 won't even crank (KCRX)
Thermostat ground and tranny housing ground?
Old Oct 17, 2008 | 04:02 PM
EF_monster's Avatar
check the ground cable on your starter to your ignition switch. if everything is good then check all your grounds and make sure the grounding surface is clean. also make sure they are all tightened down good and they arent touching anything that could cause it to short.
Old Oct 17, 2008 | 09:46 PM
God-Driven's Avatar
It has to be a ground problem, make sure that they are tight and that theres no broken wires.
Old Oct 17, 2008 | 10:09 PM
salman's Avatar
when U tried to push start, did engine rotated then??
check the following,,
at stater motor there is triger wire, u can easily look for it as stater motor have only 2 wire, one is direct from battery and the other one is trigering wire, the engine will not crank if its not connected,
If its connected, take out all the spark plugs and try again, some time water in the cylinder wont let engine crank,
2.Below throttle body there is water house pipe connected to block and the other end to radiator lower outlet, at block just above the house pipe there is ECU's And engine ground wire, check if its proper.
but the engine will crank either is connected or not..
Old Oct 18, 2008 | 06:32 AM
KCRX's Avatar
Engine did rotate. Thanks for all the help guys, checking grounds.
Old Oct 18, 2008 | 06:40 AM
zrickety's Avatar
Default Re: (KCRX)
check fuses too...you may have shorted something out
Old Oct 19, 2008 | 10:47 AM
salman's Avatar
Default Re: (KCRX)
did u checked the starter signal wire.. ?
Old Nov 29, 2008 | 05:08 PM
KCRX's Avatar
Ended up being tranny ground. Now the car cranks but no start. Been sitting for a year and half now. I suck at life.
Old Nov 29, 2008 | 05:16 PM
31flavorscivic's Avatar
floor it and hold the starter. When I first installed my ZC the engine had been sitting in a yard for so long and I had to crank until my battery was dead then hook up to my dad's truck and crank for an additional 5 minutes with the accelerator to the floor and it finally fired up.
Old Dec 1, 2008 | 07:10 AM
KCRX's Avatar
Default no luck
cranked the ish out of it. got a back fire once, that means i have spark and gas? put bigger injectors so to rich? throwing 10 and 6 code but thought it should still start
Old Dec 1, 2008 | 10:41 AM
ef9_b20's Avatar
replaced head gasket right? timing issue possibly? i know when i had backfire issues when my b16a wouldnt start i needed a new dizzy. dont know if any of that will help just throwing in my 2cents
Old Dec 1, 2008 | 01:35 PM
KCRX's Avatar
2 cents will always add up to something so I'm glad to get all the help I can get. Any way to check a dizzy or just put a new one on?
Old Dec 12, 2008 | 05:41 AM
KCRX's Avatar
Use to crank and now just rapid clicking from the starter. Could the ground still be bad? Battery is all good and so is connections.
Old Dec 12, 2008 | 05:57 AM
Black4thgenEF's Avatar
Have you done anything about the gasoline that has been sitting in the tank for a year and a half? If not, you can either fill it up with fresh gas (if there isn't too much old gas in it), or you can drain it from the bottom of the tank. You will also likely need a new fuel filter.
Another possibility is that your main relay has not lasted. Check to see if you have spark and fuel and post the results. This simple test will be a huge help in diagnosing the problem.
That rapid clicking means that your battery is dead. Time to give it a charge.
Are you positive that your timing is correct?
Old Dec 12, 2008 | 02:17 PM
ilikericedotcom's Avatar
agreed with black4thgenef. my roomates crx sat for almost 2 years and never moved or started. rust got built up in the tank and the gas went bad. id drain the tank and put fresh gas in it. then check the relays.
Old Dec 12, 2008 | 02:24 PM
LightWeightChamp's Avatar
main relay?
beco
19
Mar 26, 2022 10:08 AM
b18crx823
11
Sep 23, 2012 12:43 PM
sirrex1990
May 13, 2010 06:29 PM
vteckills40r
Mar 13, 2010 11:21 PM
ATEJ8FTW
Apr 16, 2009 09:28 PM
