What is chipping exactly?
Old Oct 16, 2008 | 09:19 PM
fryman's Avatar
Default What is chipping exactly?
I know its a question that will probably get me flammed but I've been looking around and surprisingly havent found what I'm looking for.I know you can get ecu's chipped for vtec so that the engine will run vtec but what I'm wondering about is chipping for turbo tuning....I've been told that you have to chip an ecu before you use a turbo which as far as I know is so that more fuel is injected into the engine correct?Does chipping it make it so that the ecu can be hooked up to a computer and then can be programmed or does the chip you install already have the program you need for more fuel or what?I'm so confused
Old Oct 17, 2008 | 01:19 PM
fryman's Avatar
Default Re: What is chipping exactly? (fryman)
Bump
Old Oct 17, 2008 | 06:40 PM
fryman's Avatar
I know its a newbie question but if no one wants to explain it can someone at least give me a link to someplace that explains it?
Old Oct 17, 2008 | 07:24 PM
supraccordlx's Avatar
Search my friend.
http://www.moates.net/zips/cro...3.pdf
Old Oct 17, 2008 | 07:41 PM
raidacaipo's Avatar
chipping.. adding a chip to your ecu therefore you get can get it tuned or you can use a chip that already have programs on it..
Modified by raidacaipo at 8:47 PM 10/17/2008
Old Oct 17, 2008 | 07:43 PM
solturbob16sol's Avatar
* B A N N E D *
Default Re: (supraccordlx)
its when the paint on the car starts come off hahahahaha
Old Oct 17, 2008 | 08:31 PM
VTECJUN's Avatar
Default Re: (solturbob16sol)
The best way to explain chipping....you are taking your ECU and making it capable of accepting an aftermarket chip. That chip allows you to "burn" a new program onto it and then install the chip in your ECU. This is very important when making changes to the engine. Most software programs allow you to change all the fuel values, timing values, rev limits, and VTEC engagement for starters.
Old Oct 18, 2008 | 11:54 PM
fryman's Avatar
Default Re: (VTECJUN)
Ohh ok I understand.Thanks everyone
s032105k
Engine Management and Tuning
Mar 2, 2011 02:23 PM
basiceg6
Nov 27, 2009 09:45 AM
honda23
Apr 23, 2009 06:59 PM
604Squad
Apr 28, 2006 05:42 AM
hatchmobile
Apr 25, 2002 06:15 PM
