Question about Rear Disc Brake Conversion
Old Oct 16, 2008 | 07:16 PM
sk8board{Pete}'s Avatar
Default Question about Rear Disc Brake Conversion
Picked up a comeplete rear disc conversion for 60 bucks of a 98 gs integra, but the bushing on the passenager side trailing arm is bent. I was wondering if I can you the trailing arm from my 98 ex civic to replace it?
Old Oct 16, 2008 | 09:56 PM
Bob Dole!'s Avatar
Default Re: Question about Rear Disc Brake Conversion (unvme23)
Are you asking if you can reuse the bushing or trailing arm? Both answers are yes, you'll have to press the trailing arm bushing out. Using the trailing arm you'll have to swap the disc hub with the drum hub. 4 or 5 t-50 torx bolts.
Old Oct 17, 2008 | 12:29 AM
ke98248's Avatar
Default Re: Question about Rear Disc Brake Conversion (Bob Dole!)
You can buy sweet spherical bushings to replace it, instead of using your old stock civic bushings.
Old Oct 21, 2008 | 01:44 PM
Default Re: Question about Rear Disc Brake Conversion (ke98248)
I was asking, if it was possible to use the ex trailing arm with the integra rear hub
Old Oct 21, 2008 | 03:23 PM
Bob Dole!'s Avatar
Yes it is possible!
Old Oct 22, 2008 | 06:48 AM
thanx dude
Old Oct 22, 2008 | 07:32 AM
slo_hatch's Avatar
get that siht for $60....thats a good deal.
Old Oct 22, 2008 | 08:09 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ke98248 &raquo;</TD></TR><TR><TD CLASS="quote">You can buy sweet spherical bushings to replace it, instead of using your old stock civic bushings. </TD></TR></TABLE>
Ride quality would be the garbage.
Old Oct 22, 2008 | 09:17 AM
EL Vap133's Avatar
Default Re: Question about Rear Disc Brake Conversion (slo_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slo_hatch &raquo;</TD></TR><TR><TD CLASS="quote">get that siht for $60....thats a good deal. </TD></TR></TABLE>
Yeah for a bent trailing arm.
88 EF Hatch
Suspension & Brakes
Mar 3, 2009 06:22 PM
alscrx
11
Mar 26, 2008 02:31 PM
huge230
Aug 23, 2005 12:28 PM
unknown0001
Sep 3, 2004 01:41 PM
