Replaced cap/rotor, now car won't start!
Old Oct 16, 2008 | 04:52 PM
Chrisbequick's Avatar
Default Replaced cap/rotor, now car won't start!
I decided to do some preventative maintenence today and replaced the cap/rotor on my '98 EX, d16y8. After swapping the old parts for the new parts the car won't start. I believe I have the wires on right, and I've tried a few different wire positions and it still won't start. Put the old cap back on, still nothing. I know the cylinder position is 4-3-2-1 as you're looking at the motor. How do the wires go on? I searched, and tried the wire position the only helpful thread provided, but it didn't work. Are there any ignition components )coil, module, etc.) that could have been damaged if the wires were on wrong and I tried to start the car?
-Chris
Old Oct 16, 2008 | 06:51 PM
Pensar71's Avatar
Default Re: Replaced cap/rotor, now car won't start! (Chrisbequick)
Does it crank over?.....
Start from step one.... you swaped the cap and rotor. Check the wires, specially the order in which you hook them up.
Old Oct 16, 2008 | 07:02 PM
Pensar71's Avatar
Default Re: Replaced cap/rotor, now car won't start! (Pensar71)
Hopefully this pic will help....(got it off google)
Old Oct 16, 2008 | 07:17 PM
solturbob16sol's Avatar
* B A N N E D *
maybe if you put the spark plug wires back on in the right order you wouldnt have a problem just a noob mistake
Modified by solturbob16sol at 8:36 PM 10/16/2008
Old Oct 16, 2008 | 07:24 PM
Pensar71's Avatar
Default Re: Replaced cap/rotor, now car won't start! (solturbob16sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solturbob16sol &raquo;</TD></TR><TR><TD CLASS="quote">maybe if you put the spark plugs back on in the right order you wouldnt have a problem just a noob mistake</TD></TR></TABLE>
I think he means the spark plug wires' order. That's why I posted the pic as a reference to the order they're suppose to be in. Good Luck!
Old Oct 16, 2008 | 07:39 PM
* B A N N E D *
yes i did this might help
joemommaaa
Feb 20, 2011 06:01 PM
ek98
Aug 7, 2009 07:09 PM
djjosehernandez
May 23, 2009 12:08 PM
S2KILLA
Nov 29, 2006 06:00 AM
lilgreenlude93
Apr 7, 2004 10:20 PM
