00 Dash wont light up after radio install
Old Oct 16, 2008 | 12:55 PM
black_coupe's Avatar
Default 00 Dash wont light up after radio install
Installed my new radio yesterday & today when i woke up i saw that my cluster and most of my climate control lights wont light up.When I move the dimmer the lights that do light up start flashing,what could be the problem?
Thanks in advance
Old Oct 16, 2008 | 01:15 PM
Former User's Avatar
Default Re: 00 Dash wont light up after radio install (black_coupe)
Check whether the connector at the rear of the dimmer is loose and whether the black ground wire may be damaged.
Old Oct 16, 2008 | 02:52 PM
doggworld1233's Avatar
you prob just grounded out the dimmer wire that is behind the radio. it is the red/black wire behind the radio
Old Oct 16, 2008 | 03:27 PM
Default Re: (doggworld1233)
Thanks for the reply's,I checked the connector and it seems fine & doggworld1233 so its a blown fuse??
Old Oct 16, 2008 | 03:36 PM
hatchling37's Avatar
Did you get the dimmer wire mixed up with the other illuminate wire? I mixed them up before and it took out the dash lights until I switched them...
Old Oct 16, 2008 | 04:21 PM
Default Re: 00 Dash wont light up after radio install (hatchling37)
Well im not sure,theirs a illuminate wire and a dashboard wire.I connected the illuminate wire with the appropriate color but their wasn't a second wire for the dashboard wire,could that be the problem?
wtemale
Nov 18, 2017 05:08 PM
sleEKcpe
16
Jul 23, 2010 09:23 AM
virgoafb
Audio / Security / Video
Sep 9, 2008 12:52 PM
scrolanky
Feb 24, 2004 01:54 PM
WHIT
Nov 24, 2002 08:36 AM
