fs: turbo d16y8 swap,rc,competition,egale,
Hey guys I am building a new motor everything must go. pick up only
rc 440s $250
innovative wide band gauge- gauge with dial,wiring,computer program $200
never used intercooler couplings- will find out sizes, blue
never used intercooler clamps- will find out sizes
d16 tranny 5 speed about 60 or 70 thousand miles on it $150
d16 adjustable cam gear- $35
I have a d16y8 build I am parting with. just finished it.
full swap!! you can hear it run!had it on dyno running at 200hp
to the front wheels with 16 psi. does not come with ecu,map sensor,boost controller.there might be things missing from the list will add soon.
block- under 4000 miles on motor
new crank
new crank bearings
egale rods-notched block
vitara pistons 8.5.1 compression
block guard
arp head studs
new oil and water pump
blox oil fiter block adpater
head-
crower vavle train
port and polished
new cap and rotor
new oem wires
oem intake
interga throttle body
turbo-
turbonectics t3/t4
aftermarket turbo manifold
tail 38mm wastegate
2"x5"x28(i think) intercooler with piping,clamps,connectors
blitz blow off valve
feul-
competition feul rail
rc 750 injectors
tranny-
5 speed
competition stage 2 clutch
oem shift linkage
oem axles
looking for a reasonable offer for swap
pm me with any questions
Modified by thollis97 at 12:39 PM 10/16/2008
rc 440s $250
new crank
new crank bearings
block guard
arp head studs
head-
crower vavle train
port and polished
new cap and rotor
new oem wires
oem intake
turbo-
turbonectics t3/t4
tail 38mm wastegate
feul-
rc 750 injectors
tranny-
5 speed
oem shift linkage
oem axles
Part-Out: D15B7 Turbo Block, D16Y8 Head, 500cc injectors, Greddy Turbo Kit, Intercooler, etc, etc, e
sundownz
Jan 24, 2009 03:48 PM
sundownz
Dec 4, 2007 08:15 AM
adjustable, california, cam, clutch, competition, d16y8, gear, hondatech, oil, pump, rc, setup, stage, swap, turbo
