Built D16Y8 turbo full swap
Just finished getting this back together but I now have something else I want to spend money on! Old setup went south a few weeks ago so I put this together. Short block has around 2k miles and the head (reportedly) has just over 5k.
P1 in Port Orchard did the short block build
Engine:
D16Y8 block - notched, line bored, honed and decked
Eagle rods
.020" over 9.0:1 CP pistons
Golden Eagle block guard (welded in properly)
Balanced fullsize crank
HFP bearings
New OEM oil pump
New water pump
ARP head studs
OEM head gasket
D15B head
3 angle valve grind on stock valves
Supertech Ti retainers/keepers
Supertech Ti springs
Delta 272 cam
Skunk2 intake manifold
ITR throttle body
Evo 8/9 560cc injectors
GM 3bar map sensor
Richtuned P28
New plug wires
New NGK BKR7Es
Ramhorn exhaust manifold
T3/T04e turbo
38mm wastegate with open dump
3" downpipe with electronic cutout and turndown
Custom exhaust and intercooler piping
Apexi SSQV bov
Lwt cromo flywheel
6 puck sprung clutch
PRICE IS $2k PLUS A GOOD RUNNING D15/16/17 or B16/B18/B20
I will include my rebuilt Si trans and new axles if trading for a B series
Car is running perfectly and I am still driving it, so I can take for a ride.
NO TRADES
Call or text Dustin @ 509.43O.1121 and we can discuss details.
Engine:
Eagle rods
HFP bearings
New OEM oil pump
New water pump
ARP head studs
OEM head gasket
D15B head
Delta 272 cam
ITR throttle body
GM 3bar map sensor
Richtuned P28
New plug wires
New NGK BKR7Es
T3/T04e turbo
Apexi SSQV bov
Lwt cromo flywheel
NO TRADES
mij_nagrom88
11-15-2009 05:07 PM
Part-Out: D15B7 Turbo Block, D16Y8 Head, 500cc injectors, Greddy Turbo Kit, Intercooler, etc, etc, e
sundownz
01-24-2009 03:48 PM
sundownz
07-07-2008 01:57 PM
sundownz
12-04-2007 08:15 AM
