(relatively) cheap wheels?
Old Oct 16, 2008 | 08:06 AM
arterial_black's Avatar
Default (relatively) cheap wheels?
My wheels (17 inch american racing estrellas, *very* used) are in pretty poor shape and I'm looking to get some new wheels for my 93 dx.
I'm willing to try 16 inch wheels but would prefer 17s (the car is on poorly maintained county roads alot so it helps to have that little extra clearance just in case there's crap in the road).
I'm looking for something along the lines of 5 spoke, either silver or black with a red outline. My budget for this is approx. $500 and I don't want to buy used if I can help it. Also, they need to lightweight, yet durable enough for everyday use.
Any suggestions? Thanks.
Old Oct 16, 2008 | 08:54 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (relatively) cheap wheels? (arterial_black)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arterial_black &raquo;</TD></TR><TR><TD CLASS="quote">My wheels (17 inch american racing estrellas, *very* used) are in pretty poor shape and I'm looking to get some new wheels for my 93 dx.
I'm willing to try 16 inch wheels but would prefer 17s</TD></TR></TABLE>
17" is a poor choice for your older Civic because tires aren't available in sizes that match your car. Stick with 16" or smaller. With 16", you can use 205/40-16 or 195/45-16 tires. With 15", 195/50-15.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arterial_black &raquo;</TD></TR><TR><TD CLASS="quote">(the car is on poorly maintained county roads alot so it helps to have that little extra clearance just in case there's crap in the road).</TD></TR></TABLE>
If the car is driven on poorly maintained roads, that's all the MORE reason to use smaller wheels (15" or even 14"). That way, the taller sidewall of the tire provides more protection for the wheels against damage from potholes, etc.
Old Oct 16, 2008 | 09:03 AM
ejaysix's Avatar
500 with tires? Maybe Nippon or Drag but with tires and shipping it will still prolly be more that 500...you might be able to find some local for 500 and pick it up...dont get 17s
Old Oct 16, 2008 | 09:48 AM
Default Re: (ejaysix)
Nah, the ~$500 budget is just for the wheels, tires not included. I can go a little over if need be, I just don't wanna spend $200 per wheel or anything like that.
The reason 17 inch wheels were on it is because I just pulled the wheels off of my first car (a 92 dx hatch that met a tree head on) and never really thought about it. I'm not an expert on tires or wheels either for that matter, which is why I was asking here.
16 inch I can live with... The car isn't lowered at all (it's running on an accord suspension actually, though that will probably change once I can afford a good aftermarket suspension setup) but clearance is definitely a concern.
The hatch I spoke of? It met it's fate at the hands of a tree when I lost control after trying to avoid a rather large armadillo that my hatch was too low to make it over. The hatch was my first car at 16 had been lowered way too much by the previous owner and I was too young/stupid at the time and didn't know enough about cars at that point to do anything about it. I have since learned my lesson and have chalked up at least 1 dead armadillo, a redbird (freak incident, I tell ya!), and a possum or two.
Back to the point, I appreciate the advice so far. Now, I need some buying suggestions for budget wheels.
Again, thanks.
Old Oct 16, 2008 | 10:46 AM
phoenixdown110's Avatar
New User
Default Re: (arterial_black)
I have a set of 15x6.5" Konig Heliums in bronze that should be up for sale soon. I'm asking 350 for all four.
Offset is +40. Weight is 11.5 lbs
Old Oct 16, 2008 | 03:42 PM
ejaysix's Avatar
check out jlbmotorsports.com. they are having a sale right now i think. most of the rims they have you can probably get shipped for around 500.
Old Oct 19, 2008 | 04:56 AM
Sikocivic's Avatar
Edge Racing has wheel-tire packages for $500-$600 for your car.
http://www.edgeracing.com/1993...ls/16/
Old Oct 19, 2008 | 12:53 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (relatively) cheap wheels? (Sikocivic)
Your money can go a lot further if you consider used wheels. Just for example, there are lots of sets of used alloy 15" wheels from Integra GS-R's out there to be had for ~$200 or thereabouts, and they should fit your car fine.
Old Oct 29, 2008 | 08:51 AM
@sikocivic: thanks, checking out the link right now.
@nsxtasy: I've considered GS-R wheels, but I'm really worried about clearance. Being able to drive over obstructions in the road such as dead woodland creatures is a must, and downsizing to a 15" worries me.
Old Oct 30, 2008 | 05:24 AM
alphalanos's Avatar
Smaller wheels dont lower your car if you use the correct size tire.
Old Oct 30, 2008 | 07:14 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (alphalanos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alphalanos &raquo;</TD></TR><TR><TD CLASS="quote">Smaller wheels dont lower your car if you use the correct size tire.</TD></TR></TABLE>
That's correct.
AFAIK all GS-R wheels can be used on all older Civics. You would want to use a smaller tire size - 195/50-15 instead of the GS-R's 195/55-15. OTOH if you find a set of GS-R wheels with tires, you could go ahead and use them up before replacing them with the proper tire size for your car.
Old Nov 3, 2008 | 06:55 AM
Default Re: (nsxtasy)
The tire size info is very helpful, thanks. I found some replica GS-R wheels on ebay from these guys: http://stores.ebay.com/Wheels-and-Caps
I aplogize for being new to wheels and tires, but the advice has been extremely helpful. Thanks a bunch!
Old Nov 3, 2008 | 11:08 AM
danielg's Avatar
Just a thought to ponder.
Why buy replicas if you can find the real deal for around the same price.
Old Nov 4, 2008 | 04:42 AM
Because I haven't been able to find the real deal
Plus I'm kinda hesitant about getting used wheels anyway. Unless they were absolutely mint, that is..
Old Nov 4, 2008 | 12:57 PM
efvader's Avatar
buy some rotas then man, not to much money and easy to replace
DingoAteUrBaby
Aug 9, 2010 05:59 AM
civicduty13
Nov 4, 2008 03:45 PM
RHD DA6
Aug 19, 2007 10:28 AM
CivicEKCP
34
Dec 17, 2003 09:30 PM
