aem wideband problems or fuel problems?
Old Oct 15, 2008 | 09:28 PM
Spody02's Avatar
Default aem wideband problems or fuel problems?
so i just rebuild my motor for boost, buts its not boosted lol, and i wanted to make sure my air/fuel ratio was doing ok so i welded a bung into my stock exhaust and put it and when i go WOT it goes like all the way to red side and off the gauge and shows that it 3 dashes, am i running super rich at WOT or what, its at like 14.9 for idle. Could it be a bad sensors or is my gauge broken or what?
thanks
Old Oct 18, 2008 | 01:41 AM
wHOAlly's Avatar
Default Re: aem wideband problems or fuel problems? (Spody02)
sounds like your really rich, richest readin from that wideband is 10afr
Old Oct 20, 2008 | 09:26 PM
JDM turbo DC's Avatar
476 whp / 323 tq @ 17 PSI
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spody02 &raquo;</TD></TR><TR><TD CLASS="quote">so i just rebuild my motor for boost, buts its not boosted lol, and i wanted to make sure my air/fuel ratio was doing ok so i welded a bung into my stock exhaust and put it and when i go WOT it goes like all the way to red side and off the gauge and shows that it 3 dashes, am i running super rich at WOT or what, its at like 14.9 for idle. Could it be a bad sensors or is my gauge broken or what?
thanks </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wHOAlly &raquo;</TD></TR><TR><TD CLASS="quote">sounds like your really rich, richest readin from that wideband is 10afr</TD></TR></TABLE>
no, the RED LEDs indicate lean air/fuel mixture and when it goes off the LED band at the red side and shows the dashes (indicating a measurement beyond the wideband's translation) means you are running extremely lean, to the point where you run leaner than the wideband's range of measurement, usually 20.0 max. That needs to be fixed ASAP.
Old Oct 21, 2008 | 07:22 AM
wHOAlly's Avatar
Default Re: aem wideband problems or fuel problems? (JDM turbo DC)
whoops, thought he was referencing the 3 red dashses.
ya, go get that fixed, thats retarded lean.
Old Oct 21, 2008 | 07:42 AM
Default Re: aem wideband problems or fuel problems? (wHOAlly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wHOAlly &raquo;</TD></TR><TR><TD CLASS="quote">whoops, thought he was referencing the 3 red dashses.
ya, go get that fixed, thats retarded lean.</TD></TR></TABLE>
well hopefully he read my post right away instead of reading just yours and going off to lean out the tune even more and detonate (thinkin it was rich).
jdm knight
Aug 7, 2006 06:27 PM
jdmh22luda
Jul 15, 2005 10:40 AM
turbo-d
Feb 4, 2005 04:58 PM
Teggyb18b
Dec 1, 2002 06:29 PM
Cottonwoodz
Sep 1, 2002 10:29 PM
