Stripped header stud! I F**ked up someone help?
Old Oct 15, 2008 | 08:28 PM
1200 Hobos's Avatar
Default Stripped header stud! I F**ked up someone help?
Yep, stupid A** mistake,Installed header, torqued down the studs... started car.. vibration noise, started re-torquing but the car got hot so ... strrrrrrrrrrrrrrrrrrriiiiiiiiiiiiiip goes one of the studs...
Today I went to the dealer and picked up the stud to replace it since it didn't completely break off I thought I was going to be able to save it but to no avail. PB balsted it, tapped lightly, started unscrewing the stripped stud and half of it is left inside so I'm fuked...
If anybody could come over on sunday to my house and help me fix this I'll pay you lmk plz I need help.
Check my for sale thread you could take home something from there OR name your price keep it reasonable.
I'm located in the 818 Burbank/Glendale area
Modified by 1200 Hobos at 9:46 PM 10/15/2008
Old Oct 15, 2008 | 08:50 PM
widebodyeg's Avatar
Default Re: Stripped header stud! I F**ked up someone help? (1200 Hobos)
pm'ed
Old Oct 15, 2008 | 08:55 PM
D16Y8-JDMYO's Avatar
Default Re: Stripped header stud! I F**ked up someone help? (widebodyeg)
how deep is the broken part in there? there's an exhaust shop in whittier my work deals with that takes out stripped/broken studs fairly often since it happens all the time. it would depend how much metal's sticking out.
Old Oct 15, 2008 | 09:04 PM
1200 Hobos's Avatar
Default Re: Stripped header stud! I F**ked up someone help? (D16Y8-JDMYO)
The stud intself screws about a half an inch into the head and half of that is inside so none of it is sticking out anylonger. The piece is inside the threads now.
I could make the drive to whittier.. are you guys available sunday? And what's the cost look like for somethign lke this and how long will it take?
Old Oct 15, 2008 | 09:06 PM
ackk.. what he usually does is weld a piece to the stud, then tried to torch it out. if it's IN the head.... i dunno. maybe someone has an idea. u can call the shop directly 562-695-1788 ask for javier
Old Oct 15, 2008 | 09:08 PM
1200 Hobos's Avatar
Default Re: (D16Y8-JDMYO)
Ok I'll try to give him a call thx for the quick replies
I've read about drilling out the piece then enlarging the hole one size up but I don't want to mess with it any more I just want to fix it and move on.
Old Oct 15, 2008 | 09:09 PM
sbpphoenix's Avatar
i'm pretty sure it's just fine like that, but if you're desperate you can go pick up some easy outs
Old Oct 15, 2008 | 09:12 PM
1200 Hobos's Avatar
Default Re: (sbpphoenix)
I can't drive it though. It sounds like I have a drag car. The engine is ridiculously loud because I think it's the exhaust air leaking out. It sounds like a huge airplane intake sucking in all the air in the universe. Just loud.
I'm going to also try installing the stock header tomorrow and see if that helps in the meantime... I hate when sh*t like this happens.
Old Oct 15, 2008 | 09:20 PM
Default Re: (1200 Hobos)
it really shouldn't be that loud. are you sure you tightened the other ones all the way? my friend had one nut that was completely missing and he didn't even know until we were switching out the header. also you're using a gasket right?
Old Oct 15, 2008 | 09:24 PM
sbpphoenix's Avatar
i had 2 studs missing on my motor and it ran just fine.
Old Oct 15, 2008 | 09:26 PM
1200 Hobos's Avatar
23 ft/lbs
Yeah there's a gasket. I just can't imagine it woudl be anything else.
There is one thing. I haven't been able to get my o2 sensor out of my stock header because it's on so tight there's no way of loosening it so the header I installed has just a hole there. But still, I wouldn't think that hole would make all that noise but ofcourse it could be... It specifically sounds like it's coming from the front though and seeping through causing it to whisp so loud. I swear it sounds like drag cams loping w/o the idle. Just obnoxious when you give it gas I can't drive it people look like WTH?
Old Oct 15, 2008 | 09:32 PM
tfarol's Avatar
Sound is coming from the o2 sensor hole.
Old Oct 15, 2008 | 09:33 PM
sbpphoenix's Avatar
i have a stock d series ex manifold and i might have a 4 wire 02 around
Old Oct 15, 2008 | 09:40 PM
1200 Hobos's Avatar
Default Re: (tfarol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tfarol &raquo;</TD></TR><TR><TD CLASS="quote">Sound is coming from the o2 sensor hole.</TD></TR></TABLE>
You know what, your right. If having 2 bolts missing was fine it has to be that... thanks man atleast there's some relief, I hate when sh*t goes wrong with my car. I'm goign to install the stock header tomorrow until I figure out the stripped stud thing.
Thanks everyone for the quick replies, if anybody has the tools and is still down to help me fix this the deal this is still on the table. LMK
Old Oct 15, 2008 | 09:44 PM
LSVTEf's Avatar
i got that same sh** going on right now... i got 3 studs off inside my head... its loud !!!!!!. so going to jerry's drill & tap
&lt;brokentap.com&gt; they said it would be no more then $175 for all 3 and thats with the motor in the car!!! all they need is about 6 1/2 to 7in. of room from the studs!!!!!!!! phone # is 714-836-6824!! GL
Old Oct 15, 2008 | 10:08 PM
1200 Hobos's Avatar
Default Re: (LSVTEf)
good looking out
paowa
Jun 23, 2007 01:52 PM
Project_ED8
Mar 10, 2004 11:36 AM
MooreBoost
Jul 25, 2003 05:54 PM
VSM EXtasy
Jul 9, 2003 01:18 PM
Milano97
Jun 17, 2002 12:45 PM
