Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
CRV... Dropped 2MPG
Old Oct 15, 2008 | 07:38 PM
Sxynerd's Avatar
Default CRV... Dropped 2MPG
2000 CRV 183k miles very well maintained had just gotten new plugs, wires, cap & Rotor plus 4 new tires and the Maintenance schedule is up to date.
About 1.5 months ago I changed the Fuel filter. That's all, nothing else. Between my wife and I we drive it about 5 tanks per month with equal driving for City and Freeway. Almost immediately it seemed to have lost 2MPG.
This is with 2 different drivers with consistent driving habits and is in no way a mental.
Any Ideas of the Cause?
Old Oct 19, 2008 | 05:39 AM
Tyte-S's Avatar
Default Re: CRV... Dropped 2MPG (Sxynerd)
It's colder out?
Old Oct 20, 2008 | 10:24 AM
Ross 2.0's Avatar
In a Junkyard near you.
winter blend fuel.
Old Oct 23, 2008 | 08:31 AM
Sxynerd's Avatar
No, I wish it where that... But it started doing it while it was still summer and 80*.
Old Oct 23, 2008 | 11:23 AM
Ross 2.0's Avatar
Might have an o2 sensor going south then. Really there are so many variables it's like picking a needle out of a haystack to pick it out without a check engine light.
Old Oct 23, 2008 | 12:17 PM
Tyte-S's Avatar
Default Re: (Ross 2.0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ross 2.0 &raquo;</TD></TR><TR><TD CLASS="quote">Might have an o2 sensor going south then. Really there are so many variables it's like picking a needle out of a haystack to pick it out without a check engine light.</TD></TR></TABLE>CEL?
Old Oct 23, 2008 | 03:35 PM
Panameno's Avatar
I drive a SUV as well one thing I realized is that where I fill is important. (Quality of gasoline)
I filled up at some local spot and achieved about 240 to a tank
@ Sunoco 270-300
@ BP 250-270
Old Oct 25, 2008 | 09:56 AM
Sxynerd's Avatar
Default Re: (Tyte-S)
It does have a faulty rear O2 but The rear O2 doesn't' control fuel or timing so I don't know why that would affect it.
It just started with a new symptom.
Loss of power
And it's missing when it's first started and sometimes on braking.
Both new symptoms are speratic and I can't make them happen at will nor do they happen every time the car is started.
Old Oct 26, 2008 | 09:56 AM
Sxynerd's Avatar
I got that new code... Random misfire 1, 2, 3, 4, Mfr Random Misfire. I'm Getting irritated.
Could the distributor be going bad?
Old Oct 26, 2008 | 12:00 PM
Ross 2.0's Avatar
What kind or spark plugs? If it's anything but NGK and Honda wires/ cap take that stuff off and throw it all away.
Put the old wires back on it and get a new Honda cap, rotor and plugs.
Old Oct 28, 2008 | 08:24 AM
shaggyeg6si's Avatar
on top of what ross said, which is dead on, you need to do a valve adjustment every 30K on the gen 1 crv.
Old Oct 30, 2008 | 09:22 AM
Sxynerd's Avatar
Default Re: (shaggyeg6si)
Is there a tech link on the valve adjustment?
Also, MPG just dropped even more to 300miles on this tank.
Edit: Is this correct and will it apply to my CRV?
http://www.denlorstools.com/ho....html
Edit again! lol
Is there a technique to gutting a the Catalytic Converter or do I just disconect and ram a few small pipes through it? " I'm aV8 guys wadda ya expect, "
Modified by Sxynerd at 1:37 PM 10/30/2008
Old Oct 30, 2008 | 05:57 PM
Sxynerd's Avatar
Default Re: (Sxynerd)
I changed my plugs again Although the plugs were only 3 months old they were trashed white and had about .50 worth of gap. I about crapped my pants. Autolites suck!
I also adjusted the valve lash. Now they really noisy. Is this normal to here the discernible chatter?
Old Nov 4, 2008 | 10:27 AM
yes. They get tight over time and need to be adjusted every 30k. Auto light does suck. OEM or NGK set to stock gap only.
Old Dec 12, 2008 | 01:09 PM
Charlie Moua's Avatar
Tonight I'm going to be picking up a 00 crv with 65k on it.
I'll have to test out the first 5 full tanks and let you know what I average. The car has recently had it's tune up.
Old Dec 13, 2008 | 06:21 AM
StokelesS_g2's Avatar
Are you serious Sxynerd?
You from Bay Shity? Damn, I thought I was the only one that called it that.
That's my hometown also. LoL.
Sorry to hear about your fuel problems.
Why don't you tell us how much gas mileage you're getting?
I got a 99' CR-V EX, and I'm only getting around 24mpg city/hwy driving.
Mines a 5speed also.
Mine likes premium gas better also. I put 87' in there one day, and lost a bunch of power.
I had it like that for about a week, until I could get in a fresh tank of 93' gas.
I think that gas stations are ripping people off on gallons, because of the lower prices.
I put in gas like I normally would, and now when it's near E, It fills up like 13.5 gallons now.
I thought it was just me, but it does it like that on my Integra also, and I know that my Integra only has a 13 gallon tank. LoL.
So as far as testing gas mileage goes, I don't care. I'm just glad gas prices came down.
whiteformula98
10
Dec 26, 2008 09:15 AM
99blackdc2
Oct 28, 2006 08:40 PM
z6honda
Sep 20, 2005 10:03 AM
Takashi1978
Aug 10, 2005 07:44 AM
superhatchbackbros
May 12, 2005 09:07 AM
