O2 Sensor Plug Difference
From: ....................................................................................................
Hey guys just got an O2 from the salvage yard from a 90 and up i believe accord and i went to install it because my wires got torn up on the base of my original O2 sensor so the difference that i encontered was the plugs were different the difference was the plug on mine was to plug in to plug a lets say the other o2 sensor is plug a and trying to plug into my harness so there the same, now what i wanted to ask is if i can cut and splice into the o2 harness i have now and well that work? also the o2 sensor itself is different the one i have the has more holes and the bottom of it does not have a hole it while the accord one has less holes and has a hole on the bottom. please chime in. also the reason i got it is because someone on ht told me any 4 wire honda primary o2 will work
im willing to buy it but it needs to be a 4 wire if you have one for a 94 ex i'll def buy it from you
BlueShadow
Jan 16, 2005 11:04 AM
SpeedDreamz.com
Nov 9, 2003 08:01 AM
