Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
how do you to change brake pads for 2006 civic?
Old Oct 15, 2008 | 11:24 AM
kit50si's Avatar
Default how do you to change brake pads for 2006 civic?
well i usually change my brake pads but when I tried to take out the bolt to swing the caliper open the bolt would just spin and i see a plate that seems to turn while i turn the bolt do i need a special tool for this job?
Old Oct 15, 2008 | 11:54 AM
2008fijibluesi's Avatar
Default Re: how do you to change brake pads for 2006 civic? (kit50si)
Here are two DIYs. You didn't specify what vehicle you have (or if you were doing front or back pads), so I got you front and back.
FRONT > http://www.8thcivic.com/forums....html
BACK > http://www.8thcivic.com/forums....html
If you haven't visited 8thcivic.com, give it a look. I find both H-T.com and 8th to be helpful for different things, but 8th has a pretty large, and specific DIY section. This Civic (2006-Current) forum used to have a DIY section but it was removed.
Good luck.
Old Oct 15, 2008 | 12:09 PM
SIVIC 3's Avatar
your unscrewing the wrong bolt.
Old Oct 15, 2008 | 12:20 PM
kit50si's Avatar
Default Re: how do you to change brake pads for 2006 civic? (2008fijibluesi)
thanks brand new to this model that helps alot
Old Oct 15, 2008 | 12:35 PM
kit50si's Avatar
Default Re: (SIVIC 3)
what bolt ? i was doing almost what the picture is showing except for the wrench on the pin. which bolt is it?
Old Oct 15, 2008 | 12:49 PM
pd0019's Avatar
Default Re: (kit50si)
so you have the normal bolt that you unscrew to lift the caliper up. take a 19mm wrench (i think) and use it to hold the pin thats right in front of the bolt, and unscrew the bolt and it will come off.
martin31
Suspension & Brakes
Mar 15, 2014 05:26 AM
96CivicEXSedan
19
Dec 13, 2013 03:36 PM
Mishako129
Aug 13, 2013 06:56 PM
90da4dr
Jun 5, 2004 10:46 PM
blkgsr03
Mar 4, 2003 04:11 AM
