gsr seats in a 98 ej8
Old Oct 15, 2008 | 05:37 AM
wrenchez81's Avatar
Default gsr seats in a 98 ej8
will 97 gsr seats directly bolt in w/o heavy mods to the tracks???
Old Oct 15, 2008 | 08:13 AM
sintype's Avatar
it will work i think, but you can only bolt in down on 3 sides.
Old Oct 16, 2008 | 02:35 AM
wrenchez81's Avatar
something a drill and tap set cant handle??
Old Nov 6, 2008 | 03:43 PM
lando26's Avatar
yo idk how 2 message but here r some better pics and wut u tryin 2 trade 4?
Old Nov 6, 2008 | 04:32 PM
mattyv's Avatar
Don't thread jack make your own thread. Oh wait... it got locked.
i believe all holes line up accept one. correct me if i'm wrong
Old Nov 6, 2008 | 07:15 PM
scbmx87's Avatar
Default Re: (mattyv)
3 of the 4 holes will line up. Just unbolt the rails off of your EK seats and bolt them to the Teg seats, then all 4 will bolt in. Takes a couple minutes and it'll fit like stock! I just did it to mine.
Old Nov 6, 2008 | 07:42 PM
xxjokoxx's Avatar
correct...just replace the teg rails with your EK rails and your good. Replace the seatbelt side of the rail. The inner rails. In other words the left rail on the passenger side and right rail on the driver side. All 4 bolts will bolt in. You might have to push on the rail a lil bit to get the bolts in but its simple. If you want the back seats...4dr teg seats should bolt up so it'll match the fronts.
Old Nov 6, 2008 | 08:08 PM
mnskateboarder's Avatar
Default Re: (xxjokoxx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxjokoxx &raquo;</TD></TR><TR><TD CLASS="quote">correct...just replace the teg rails with your EK rails and your good. Replace the seatbelt side of the rail. The inner rails. In other words the left rail on the passenger side and right rail on the driver side. All 4 bolts will bolt in. You might have to push on the rail a lil bit to get the bolts in but its simple. If you want the back seats...4dr teg seats should bolt up so it'll match the fronts.</TD></TR></TABLE>
But doesnt replacing one side make them sit lop sided? I did the same with my gsr seats, swapped the inner rail only, and they sat funny. Now i just use the stock gsr rails and only have 3 bolted in and holds perfect.
Old Nov 7, 2008 | 06:46 AM
gsrturbo-ek's Avatar
Default Re: (mnskateboarder)
you can use the teg rails just the back inner bolt wont bolt up since the rail is shorter what im goin do is get some heavy guage metal strip and bolt that into the hole in the floor and leave a piece hangin over the teggy rail andf it wil hold it sturdy
Old Nov 7, 2008 | 09:55 AM
DeucesWild's Avatar
https://honda-tech.com/zerothread?id=1436635
faq's are your friend
StuckInTexas
Oct 18, 2015 05:54 PM
sokudo88
Nov 30, 2011 07:21 AM
GSR-TRBO-DA
10
Aug 15, 2007 12:18 PM
a2dadamm
Dec 30, 2005 10:33 AM
Jonathan_ED3
Aug 8, 2002 09:34 AM
