Is it possible for the T-belt to have skipped a tooth and the timing still reads perfect at the cran
Old Oct 14, 2008 | 09:14 AM
wakaranai's Avatar
Default Is it possible for the T-belt to have skipped a tooth and the timing still reads perfect at the cran
I am experiencing a bogging issue before 3800rpm. I can't use more than 15% of the throttle otherwise it bogs and even begins to slow down. From past experience, it REALLY feels like the timing is off, but it's not according to the crank marks. I went to get the car smogged and the timing was spot on and it passed with flying colors.
Now this is what I have done to try to fix this:
New Fuel Filter
New Distributor/Coil
New Plugs
The only other thing that I imagine it could be is a bad fuel pump. It primes fine and everything, but I have no way of measuring the pressure.
Any help greatly appreciated. I was selling this car and this issue came up
Old Oct 14, 2008 | 10:36 AM
accordaffair's Avatar
I'm dealing with a similiar problem, I'm replacing my distributor and the ecu could also be to blame
Old Oct 14, 2008 | 10:47 AM
jdmrex90si's Avatar
i had that same problem tryed fixing it with all the ways you guys did and then one day i changed my header got a new o2 sensor and it went away
Old Oct 14, 2008 | 08:38 PM
91civiccross's Avatar
Default Re: (jdmrex90si)
If this is an SI the crank will line up but the cam gear will not line up with the mark on the cover. When you put the timing belt on they are to be lined up. But once to tention the belt, the marks no longer line up on the marks.
The crank is at TDC and the cam gear is one tooth clockwise off of the mark.
Does the car idle ok?
Modified by 91civiccross at 9:45 PM 10/14/2008
Old Oct 14, 2008 | 09:24 PM
wakaranai's Avatar
Default Re: (91civiccross)
Yup. It idles fine. The car is actually an 86 CRX Si, but I figure I would get a faster reply here and I'm always in here anyways ( I also have an 88 Si).
Car is now for sale. Don't want to deal with it: http://www.hondamarketplace.co...08939
Old Oct 15, 2008 | 10:38 AM
May not make any difference now, but I got a new dizzy in mine and it's working now
Old Oct 15, 2008 | 10:45 AM
Duane_in_Japan's Avatar
Default Re: (accordaffair)
If the MAP sensor voltage going back to the computer is very very near 1 volt then the timing belt should be perfect, clamp off the return fuel hose going back to the tank, this is called dead head pressure, if your problem clears up then you have a fuel delivery problem, otherwise you should get it oscilloscoped during a test drive to see if its a fuel or ignition problem.
LeegodaEG
May 6, 2013 08:33 PM
mpower325
Apr 25, 2007 05:33 PM
NC-B17A
Mar 10, 2003 09:20 PM
00civicvtec
Oct 5, 2002 06:44 PM
Gasoline Fumes
Sep 25, 2002 05:28 PM
