t3/to4b ls vtec?
Old Oct 13, 2008 | 09:35 PM
civichatch2307's Avatar
Default t3/to4b ls vtec?
hi guys i curently have a turboed b16 with a t3/to4b 54trim 63a/r turbo i just took it to the dyno and it made 286hp and 210ftlb but my question is im building a built ls vtec and my goal is to make around 400hp on pump gas will my t3to4b be enough turbo or should i step it up to a t3t4oe or what would be a good turbo or tha set up considering i have a manifold with a t3 flange and dont want to buy a new one?
Old Oct 14, 2008 | 05:36 AM
Schister66's Avatar
Man U FTW
That turbo might be big enough to make your goals depending on how efficient it is up top. If i had to guess, i'd say you'll get close with that one. If you have the money though, there are several other options you could consider upgrading to...
What are you using the car for?
What's your budget for another turbo?
What characteristics (spool, powerband, etc) do you need in a new unit?
Old Oct 14, 2008 | 06:39 AM
TheShodan's Avatar
Moderator
400whp on PUMP gas? No. He'll need race gas for that at least before that size will putter out a bit.
Old Oct 14, 2008 | 06:43 AM
Schister66's Avatar
Man U FTW
Default Re: (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">400whp on PUMP gas? No. He'll need race gas for that at least before that size will putter out a bit.</TD></TR></TABLE>
I suppose...im always in the mindset that everyone has access to E85 these days
Old Oct 14, 2008 | 04:16 PM
blinx9900's Avatar
Default Re: (Schister66)
400whp on that turbo is a stretch with any kind of gas, i would bet that it will make that power on race gas but won't last too long and I hope you have an efficient intercooler or you definately will not hit 400 with that turbo...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">
I suppose...im always in the mindset that everyone has access to E85 these days </TD></TR></TABLE>
must be nice...
Old Oct 14, 2008 | 09:30 PM
HiProfile's Avatar
That should be a S-trim, 50mm/70mm in/exducer sizes. The turbo flows about 37lb/min as per Garrett, and is known to do 350whp in a perfect world. For compairison, a 57trim t3/t04E puts out 47lb/min, and can do around 450whp with over 22 PSI. Given E85 was mentioned, that turbo very well could make 400whp. Tony1 told me he normally sees gains of 8% with E85 over normal pump gas. Better bumpsticks and more displacement could be the other thing to help the turbo out.
One thing that will really determine what your limit will be is the turbine. I have a t3/t04b S-trim with a .48ar housing over a STG1 turbine. That means I'll hit 300whp with it if I get REEEALY lucky. A .63ar/STG3 housing/turbine can max out that compressor far easier. Just remember your turbo will start to suck after 20psi in almost all cases.
CLIFFS: LS-V/E85 FTW. $600 for a T3/T04E 57trim will get you to 400whp easily, your T3/T04B 54trim not so easy.
EJ8Squad919
Jun 6, 2012 07:31 PM
1lsvtecturbo1
Feb 22, 2009 10:55 AM
ralph11sec
Jul 7, 2008 03:17 PM
Peter Shen
Feb 26, 2007 12:40 PM
turbosol_16
Jan 3, 2007 09:38 PM
