K24 vs B20B
Old Oct 13, 2008 | 07:49 PM
Cestparti's Avatar
Default K24 vs B20B
Hey i am looking to swap my engine in spring. I was looking at getting the B20B. I was going to look into buying the engine or buying a crv from mpi. I found a 2002 crv the body is crap but the engine is mint. So I was wondering. Is it alot harder to swap in a B20B compared to a K24? Thanks
Old Oct 13, 2008 | 08:22 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: K24 vs B20B (Cestparti)
search both B and K swaps are covered.
Old Oct 14, 2008 | 12:36 AM
spoolin94ls's Avatar
Default Re: K24 vs B20B (***$nyper)
b20 would good if on a budget but if u have cash flow go with the k24. b20 is the easier swap to do compared to the k24.
Old Oct 14, 2008 | 03:20 AM
DCFerris's Avatar
you have to factor in what you want your car to do go only in a straight line or go around turns a 2.4 liter is a big big motor you gonna get a lot of under steer with that i would say just build the b20 with the money your gonna save
Old Oct 14, 2008 | 03:25 AM
davidu's Avatar
i thought the whole weight issue with the k motors was put to bed already?
as in it isnt enough to cause any concern.
also i was under the impression that the size of your motor had no impact on understeer.
regardless you can tune the steering to neutral anyway.
once again the only two questions that matter when it comes to motor selection are
1. what are you going to do with your car
2. how fast can you afford to go
if you are like 99% of the people here you arent going to race your car. taking it to the strip once a year isnt racing btw. 99% of the people here just want to have something cool to show their friends. in that case it really doesnt matter what is best. it only matters what your friends think is best, and what is one step up from what they all have.
Old Oct 14, 2008 | 05:48 AM
Cestparti's Avatar
it sounds like the k24 is alot more work. Ill talk to my buddy whos going to do the work in swapping it. I think i am going to stick with the b20b. IF there are any more tips or anything involving the k24 let me know thanks alot!
Old Oct 14, 2008 | 06:58 AM
Red_ED8's Avatar
Default Re: (Cestparti)
The K24 is NOT a lot more work and is NOT a lot (if any) heaver then the B20.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davidu &raquo;</TD></TR><TR><TD CLASS="quote">i thought the whole weight issue with the k motors was put to bed already?</TD></TR></TABLE>
It was been time and time again, the K20 is roughly 4 lbs lighter then the B18C5 so take that into consideration. And what car is this going into? The only down side I see to the K24 is the block is too tall, it will not fit under a EF hood.
Old Oct 14, 2008 | 07:14 AM
CRX Toad's Avatar
Default Re: (Red_ED8)
On the weight issue, I do not like the way that the K series moves the weight to the nose of the car. A B series weight sits further back in the engine bay. A K maybe lighter and more powerful but I do not like the changes in vehicle dynamics.
Old Oct 14, 2008 | 07:54 AM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
Default Re: (CRX Toad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">On the weight issue, I do not like the way that the K series moves the weight to the nose of the car. A B series weight sits further back in the engine bay. A K maybe lighter and more powerful but I do not like the changes in vehicle dynamics. </TD></TR></TABLE>
^^^What he said^^^
I miss your nuggets of wisdom
Old Oct 14, 2008 | 09:22 AM
sanimalp's Avatar
$cat /dev/urandom
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red_ED8 &raquo;</TD></TR><TR><TD CLASS="quote">The K24 is NOT a lot more work </TD></TR></TABLE>
I would have to respectfully disagree with that.. b20 uses bolt in mounts. that alone is a lot less drama, on top of the fact you don't need custom axles and the wiring is a lot less drama.
k-series is only for people who either A) have $8k-$9k to throw at the car or B) a veteran honda swapper that knows the car inside and out, and still has atleast $5k to do the job, and a lot of patience..
for newb friendliness, i have to say the b20 is the way to go. the k is hands down a better engine though, and worth every penny...
Old Oct 14, 2008 | 09:44 AM
Ass$nyper's Avatar
If they ever sort that out though.
Old Oct 14, 2008 | 09:49 AM
Red_ED8's Avatar
Default Re: (sanimalp)
There is a lot of good info and opinions in where but it all boils down to:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davidu &raquo;</TD></TR><TR><TD CLASS="quote"> the only two questions that matter when it comes to motor selection are
2. how fast can you afford to go</TD></TR></TABLE>
Old Oct 14, 2008 | 10:43 AM
EF-8SiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red_ED8 &raquo;</TD></TR><TR><TD CLASS="quote">The only down side I see to the K24 is the block is too tall, it will not fit under a EF hood.</TD></TR></TABLE>
What about the jdm sir crx hood? its a scoop instead of the usdm inverted hood. Just seeing if anyone would know
Old Oct 14, 2008 | 03:37 PM
Red_ED8's Avatar
Default Re: (EF-8SiR)
I'm not sure but I don't think the sir hood will clear, but I could be wrong (I've never seen a EF with a K24). Check out K20a.org
http://www.k20a.org/forum/index.php
You will find better answers there .
Old Oct 15, 2008 | 07:22 PM
EF-8SiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red_ED8 &raquo;</TD></TR><TR><TD CLASS="quote">I'm not sure but I don't think the sir hood will clear, but I could be wrong (I've never seen a EF with a K24). Check out K20a.org
You will find better answers there .</TD></TR></TABLE>
thanks!
Old Oct 16, 2008 | 07:52 AM
SVPCEO's Avatar
You gots money go K-series........heres a few teasers pictures of my buddies cars.....
If you are on a buget go b20.....All these cars swithcover from b-series to k motors and they love there new set ups.........
Old Oct 16, 2008 | 02:09 PM
Red_ED8's Avatar
Default Re: K24 vs B20B (SVPCEO)
Old Jan 30, 2009 | 02:21 PM
ALLxMOTOR EG's Avatar
Vietnamese!
listen to crx toad!
Old Jan 30, 2009 | 02:32 PM
NlCK B's Avatar
Originally Posted by ALLxMOTOR EG
listen to crx toad!
agreed but that's if you want your car to handle good if your all about straight line power than it doesn't really matter
b18integraboy
Mar 30, 2008 08:42 AM
kaspur_eh
Apr 29, 2004 04:04 PM
sergionuneschang
Apr 23, 2004 08:13 AM
NightHawkC5
Jan 13, 2003 03:47 PM
burnett999
21
Aug 23, 2002 09:25 AM
