10.1 cr ECU (USDM) running a 11.1 cr engine(Type S)... any problems?
Old Oct 13, 2008 | 03:21 PM
moe.'s Avatar
Default 10.1 cr ECU (USDM) running a 11.1 cr engine(Type S)... any problems?
Apparently I am an idiot and say "the most stupid thing [people] have ever heard." So to educate myself does anyone have an opinion if this would work or not. Why, why not? Any reliability issues for a DD? Emissions? Cause I was told the cr means nothing.
Modified by moe. at 4:27 PM 10/13/2008
Old Oct 13, 2008 | 03:40 PM
Speedra500's Avatar
Default Re: 10.1 cr ECU (USDM) running a 11.1 cr engine(Type S)... any problems? (moe.)
it will probably have more timing advance
Old Oct 13, 2008 | 04:44 PM
98vtec's Avatar
moderator emeritus
Default Re: 10.1 cr ECU (Speedra500)
You'll be ok. If you run into any detonation you can run a colder plug or retard the timing if you have an obd1 distributor.
MotorSpecies ver1.6
Dec 7, 2006 11:37 AM
See Are X
May 26, 2006 08:09 PM
stupidfast
Aug 14, 2003 09:08 PM
boost fed ls
Aug 11, 2003 08:26 AM
qwklude82
Jan 11, 2003 11:49 PM
