K&N intake, AEM, Injen, Fujita, Weapon R, AFE intake sale
K&N intake system
K&N 57i Series Intake Kits will make you wonder how you could have missed on a high-performing product? These Gen I Intake Kits are the only way to maximize airflow and engine performance in some applications. However, these kits are compatible with almost every application. They are ideal replacements for factory air box and offer both High-Flow air filter technology and a larger air filter size to enhance the horsepower gains.
Different 57i Series Intake Kits are available for different vehicles. Thus, you are relieved from the size restriction that comes packaged with the factory air box. The unique manufacturing process ensures that these kits are not only light on the pocket, but can also take different forms based on vehicle characteristics and available space under the hood. Power throughout the RPM range is guaranteed. These Gen I Intake Kits utilize the added airflow provided by an oversized air filter released from the restrictive factory air box.
K&N 57i Series Air Induction Kit
K&N 57 Series Gen II Fuel Injection Performance Kits (FIPKs) are multi-vehicle compatible and an improved version of K&N O/E replacement filter alone. These Air Intake Kits utilize only non-metallic rotationally molded tubes that have a greater capacity to reduce air temperature and decrease intake sound over a metal tube. The factory air path leading to the engine can often prove to be a limitation in the airflow chain resulting in the loss of horsepower. However, with K&N Air Intake Kits, this limitation is effectively taken care of by replacement of air filter and the entire path to the engine. More power is achieved by driving excess amount of air into the engine through aerodynamically engineered tube drives.
K&N 57-Series FIPK Intake
K&N 63 Series Air Intake Kits (AirChargers) are manufactured for different vehicles and constitute a marked improvement over a K&N O/E replacement filter alone. These Air intake Kits are a sister product to K&N 57 Series Air Filter Kits. K&N 63 Series Air Intake Kits (AirChargers) utilize only non-metallic rotationally molded tubes that have a greater capacity to reduce air temperature and decrease intake sound over a metal tube. The factory air path leading to the engine can often prove to be a limitation in the airflow chain resulting in the loss of horsepower. However, with K&N Air Intake Kits, this limitation is effectively taken care of by replacement of air filter and the entire path to the engine. More power is achieved by driving excess amount of air into the engine through aerodynamically engineered tube drives.
K&N 63-Series Aircharger Intake
Typhoon Air Intake System is designed ONLY for high performance! This Air System is made from mandrel-bent aluminum tube induction and is ideal for most of the sport compact performance vehicles. Rear-wheel dynamometer is used on every kit to increase the horsepower and torque. Available in three designs - Cold Air (CA) intakes, Short Ram (SR) intakes, or Complete Cold Air (CCA) intakes, Typhoon Air Intake System feature colored powder coating and polished aluminum. These high-quality Air Intake Systems feature oversized High-Flow conical air filter, which provides enhanced surface area and dust capacity. A standard K&N O/E replacement filter limited to the size of the factory air box, but this extra filter size not only enables more airflow at lower restriction, but also captures and traps more dirt, which increases its service life before a cleaning is required (up to 100,000 miles).
K&N 69-Seires Typhoon Cold Air Intake
K&N 77 Series Air Intake Kits are specially designed for trucks and SUVs. Their under-the-hood style, with metallic finish sets them apart from the competitors. The polished finish kit parts end in "KP", and gray finish kits end in "KG". And, of course, coming from K&N stable, 77 Series Air Intake Kits are high on performance front.
K&N 77-Series Performance Intake
K&N High-Flow Air Intake Systems and K&N High-Flow Air Filters have been in market since 1969 with tremendous results and outstanding feedback. For all these years, K&N has satisfied thousands of automotive and motorcycle enthusiasts by designing, manufacturing and enhancing High-Flow Air Filters and enabling them to achieve maximum horsepower and acceleration. Till date, over 2,400 High-Flow Air Filters and over 500 High-Flow Air Intake Systems have exited from the K&N factories to POWER several modern passenger vehicles. The company has emerged as numero uno in terms of number of applications in the automotive industry. K&N has also invented the High-Flow category and the High-Flow Technology, which support K&N High-Flow Air Intake Systems and K&N High-Flow Air Filters. To their credit, K&N High-Flow Air Filters are the only air filter systems used at the Indianapolis 500 Race.
K&N OEM filter
K&N intake system
K&N OEM filter
Fujita intake sale Free Shipping to 48 states
Fujita Cold Air Intake Systems enhances the performance and durability by employing aerospace-quality Mandrel-bent 6061 T6 aluminum alloy tubing on all intake pipes, and CNC-machined aluminum for adapters and flanges. The industrial-grade T-bolt clamps used in these systems secure the hoses between the intake tube and intake adaptor simulates the stuff used to secure the pressure pipes on high-powered turbocharged motors. The built-in vortex generator works to increase the low- and mid- range power. The USP of Fujita Cold Air Intake Systems is the high-polished show-quality finish, which amply complements its performance.
Fujita Short ram intake
Gain More horsepower and torque from your car with a car Fujita Short Ram Air intake, Each application of Fujita Short Ram intake air intake is Fine Tuned and dyno proven to increase horsepower and torque over stock.
After installing a Fujita Short Ram air intake you will notice better gas mileage and increase in horsepower. What else can you ask for from a intake system, you will also notice a better throttle response and more agressive engine sound after equip with a Fujita Short Ram air intake.
* Fujita Short Ram air intake out perform any other comparable Short Ram air intake in the Market for your car
* Fujita Short Ram air intake include everything for installation and guarantee perfect fit everytime
* Fujita Short Ram intake are available in Polish, Champion bronze (some application) and Wrinkled Black(some application)
* All Fujita Short Ram air intake comes complete with HoseTechniques silicone hose
* Fujita Short Ram air intake provides comprehensive installation instructions, Fujita decals and a license plate frame and all hardware for installation
* Fujita Short Ram Air intake are manufactured and assembled in the USA
Fujita Air Intake Systems are designed with state-of-the-art technology and equipped with cutting-edge aerospace-quality Mandrel-bent 6061 T6 aluminum alloy tubing on all intake pipes, and CNC-machined aluminum for adapters and flanges. What makes Fujita Air Intake Systems so special is the use of industrial-grade T-bolt clamps for securing the silicone hoses between the intake tube and intake adaptor. This is the same material used for securing the pressure pipes on high-powered turbocharged motors. Another striking feature about Fujita Air Intake Systems is the use of built-in vortex generator to increase low- and mid- range power to generate dyno-proven results. All Fujita Air Intake Systems, except the special editions, are available in a high-polished show-quality finish.
Fujita Short Ram Intake
AEM Intake System
AEm bypass valve
AEM Bypass Valve takes away all your remote concerns regarding water getting sucked into the AEM Cold Air Intake, causing hydro-lock or other engine problems. Normally, you won't face any problem with any of the AEM products, but a little caution could easily save you from unexpected trouble that could easily cause other serious problems with the engine.
AEM Bypass Valve is designed keeping in mind every intake in the market. But the best results are achieved if you use it with AEM Cold Air Intake. All you'll require is the knowledge about the size of the desired piping and the AEM Bypass Valve, when fitted, will do its job to perfection.
AEM Bypass valve
AEM Air Filter Cleaning Kit
AEM Cleaning Kit
AEM Cold Air Intake
Among all its competitors, AEM Cold Air Intake offers the best, easiest, and most affordable
modification, which is vital for increasing power. AEM allows greater intake of cold air to the
throttle body to achieve increased power output. Every intake component is carefully designed and
manufactured to make AEM the market leader in the Air Intake Systems segment.
Aem Cold Air Intake
AEM Hybrid Intake Kits
AEM hybrid Intake System
AEM short Ram intake
AEM Short Ram Intakes are comparable with the best in the industry. These C.A.R.B. certified intakes have literally taken the market by storm with their performance, fit and finish. Available with a complete hardware kit with soft mounts that guarantee excellent fit, the AEM Short Ram Intakes feature a one piece, four layer, cotton-gauze AEM filter with an exclusive air horn design for an unparalleled performance. Manufactured and assembled in the USA, the kit for AEM Short Ram Intakes comes with complete installation instructions, AEM decals, and a license plate frame.
AEM short ram intake
AEM V2 intake
AEM V2 Intake Systems have adopted a dual chamber to create a buzz in the Air Intake systems. This dual chamber utilizes two different diameters and lengths of piping to achieve multiple frequency sound waves, which in turn, play an important role in charging the cylinders with air throughout the RPM range. These new V2 Intake kits from the AEM stable have outperformed even the original Cold Air AEM Induction Systems.
AEm bypass valve
AEM Bypass valve
AEM Cleaning Kit
AEM Cold Air Intake
Aem Cold Air Intake
AEM V2 intake
Injen intake System
Injen Short Ram Intake System
For the enthusiast who is looking for a polished, show quality system Injen offers the traditional "under the hood" intake. Each Injen air intake system is engineered for both aesthetics and peak performance and then tested over and over again on a dynomometer for maximum horsepower gain and torque. All components are manufactured in the USA and each kit comes complete with all necessary hardware and vibra-mounts. Injen is the only manufacture that offers such a wide spectrum of applications.
http://www.erzperformance.com/...2.htm
Injen Race Division intake systems are engineered to perform at peak level when horsepower and torque are called for. Each Injen air intake system is CNC mandrel bent utilizing only the best aerospace alloys for a smooth, light weight aluminum bend. Injen select precise tube length, diameter and bend radius for each application to maximize air-flow and performance giving you the best engineered cold air intakes available in today's competetive market. Each Injen air intake kit comes equipped with hardware, vibra-mounts and CNC machined brackets that are tig welded to each intake for a perfect show-quality fit every time.
http://www.erzperformance.com/...3.htm
Neptronix
Jun 25, 2007 09:39 PM
