HELP!!!???
ok so not too sure wth is up with my motor just explain situation...motor on idle revs up and down like theres a vacuum leak but then becomes normal idle then i hit a rev and then it does the same thing again....idles at 1500 rpm drops and jumps to 1500 rpm....
motor d16y8
help!!
guess is some sensor
checked if intake mani was kracked-no
im a rookie sooo help!
motor d16y8
help!!
I don't know if a d16 has fast idle valve but my integra does. Its located rite under the throttle bottle. Just take that out and clean it. There's this one thing in there and if its loose, then tighten it. Clean it with carb cleaner or something like that. Take a pic of your throttle body.
cadwiese
11
Feb 26, 2012 09:32 PM
jdmdseries
Jan 23, 2008 05:52 PM
spencedogg
Jul 21, 2003 08:29 PM
