Knocking noise after brake job
Replaced my front brakes and rotors today. Afterwards, I noticed a knocking noise in the front of the car. I'm assuming the wheel/brake area. The knocking noise increases with speed and rpm. Could this be caused by sticking pads rubbing the rotor, or improper torquing of the wheel nuts?
I don't hear the noise while braking or turning, only while going straight.
Update, so I removed the rotors and pads on both sides, then reinstalled everything and torqued every bolt. Its still doing it.
I'm not sure if this is possible, but could it be that the "squealer" indicator tab was installed wrong and is touching the wheel?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hostile1 »</TD></TR><TR><TD CLASS="quote">I'm not sure if this is possible, but could it be that the "squealer" indicator tab was installed wrong and is touching the wheel?</TD></TR></TABLE>
Thanks for the suggestion but these pads don't have an indicator tab, so that rules that out.
Could bad guide pins cause the pads not to retract and make the caliper hit the pads or rotor?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDRETTI »</TD></TR><TR><TD CLASS="quote">i would wait to see if it goes away... im thinking sometimes you hear a knock on a fresh set up...idk</TD></TR></TABLE>
I doubt it, I've done dozens of brake jobs, this is a first. And on top of that, it's my GF's car, so that makes me even more paranoid.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSracing94 »</TD></TR><TR><TD CLASS="quote">what about the metal pins that hold the brake pad in place? are they still there?</TD></TR></TABLE>
Brake pad retainer clips are brand new and installed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietnamezerice »</TD></TR><TR><TD CLASS="quote">is it only making noise on one side?</TD></TR></TABLE>
Not sure, but it does sound like it's coming from the driver side.
pcguy760
Apr 8, 2007 03:52 PM
