D15B7 Pistons
I ended up getting a D15B7 as the swap engine. Of my choices of the D16y8 and the d15b7 with a 99 Y8 Vtec head, i went with the d15b7 becaues the y8 was in very crappy condition and was leaking oil and ****. So now i have this high compression bullshit. Which is terrible for my project since I want to go boost. I was wondering if Vitara pistons fit in that block or any other cheap pistons I can put in there to lower the compression so I can boost it. Because finding another engine is becoming a pain. I only want to hit 200WHP cuz its my daily driver. Any suggestions? Does anyone know if its possible?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StylishDOHC »</TD></TR><TR><TD CLASS="quote">Buy some 75.5 Vitaras & forged rods and you will be good to go.....you could run it as a standard mini-me but make sure you get a good tune.</TD></TR></TABLE>
are u sure i could boost @ all on a standard minime? the Compression ratio is like 10.3 or something according to honda compression calculator.
I suggest all forged internals, but the viatras long as they are dished ones and some forged rods would be better than none at all,, you could boost with out touching the engine at all,, but ur not going to run many lbs of boost maybe 4-6lbs looking at 160-180hp with out decreasing the life of ur motor quite a bit. Just do it right the first time,build it for boost. or your just going to be pulling it apart later doing the same thing you would be now
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jimmy o. »</TD></TR><TR><TD CLASS="quote">you wouldnt be able to run much boost on that compression and stock internals as for another motor come get this one i have
What motor do you have? I'll come get it
Or send you $ for shipping haha.
</TD></TR></TABLE>What motor do you have? I'll come get it
so its not the vtec-e one?
if not then its prolly this one
D15B
Displacement (cc): 1493
Power (bhp@rpm): 130@6800
Torque (ft/lbs@rpm): 14.1kg/m@5200
Compression Ratio: 9.6:1
Bore (mm): 75
Stroke (mm): 84.5
Cam Design: sohc
VTEC?: yes
OBD:
Year(s) Produced: 1991-1999
In the following car(s): Honda Civic VTi (EG4)
D15B
Bore (mm): 75
Stroke (mm): 84.5
Cam Design: sohc
VTEC?: yes
OBD:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jimmy o. »</TD></TR><TR><TD CLASS="quote">that looks right no its not VTEC-E thats the D16Y5 your thinkin of</TD></TR></TABLE>
nah there are 3 d15's that have vtec-e
D15Z8
* VTEC-E
* Found in:
o 1997-2000 Honda Civic LS (European Market)
+ Displacement : 1493 cm³
+ Bore and Stroke : 75 mm X 84.5 mm
+ Compression : 9.6:1
+ Power : 84 kW (114 hp) @ 6500 rpm
+ Torque : 134 Nm (95 lb·ft) @ 4500 rpm
+ VTEC Switchover : 4700 rpm
+ Valvetrain : SOHC VTEC-E (4 valves per cylinder)
+ Fuel Control : OBD2 MPFI
D15Z6
* VTEC-e
* Found in:
o 1995-2000 Honda Civic 1.5 iLS (European Market)
+ Rod Length : 137 mm
+ Power : 115 hp (86 kW) @ 6500 rpm
+ Torque : 100 lb·ft (141 Nm) @ 4800 rpm
+ VTEC Switchover : 2500 rpm
+ Fuel Control : PGM-FI MPFI
D15Z1
* VTEC-E
* Found in:
o 1992-1995 Honda Civic VX
o 1992-1995 Honda Civic VEi (European Market)
+ Compression : 9.3:1
+ Power : 90 hp (67 kW) @ 5600 rpm & 98 ft·lbf (133 N·m) @ 4800 rpm
+ ECU Code : P07
+ Fuel Control : OBD-1 MPFI
Either way, that engine sounds great. PM about it?
are there no pm's on this board? do u have some form of IM i could talk to you on?
Modified by Jimster480 at 7:26 PM 10/13/2008
D15Z8
* VTEC-E
* Found in:
D15Z6
* VTEC-e
* Found in:
D15Z1
* VTEC-E
* Found in:
+ ECU Code : P07
9civic7
11
Oct 1, 2021 03:29 PM
shiftgear8000
Oct 20, 2004 04:51 PM
95civicSirCoupe
May 15, 2004 09:13 PM
