b18b1 turbo questions
Old Oct 11, 2008 | 05:17 PM
tunerboy90's Avatar
Default b18b1 turbo questions
i just swapped a 1998 b18b1 into my 1990 integra...im aware that this motor will hold 12 psi safely with stock internals...i plan on doing 12psi with a t3/t4 turbo with a 255 pump and 550cc injectors...waht kind off power sould i be expecting at the wheels with no tuning?...mind you i will not always be in the peddle...this is my daily driver and i only plan on having my foot in it on the weekends
Old Oct 11, 2008 | 06:47 PM
Jayman_Gsr's Avatar
Default Re: b18b1 turbo questions (tunerboy90)
Well If you don't have any kind of tuning you don't want to run any boost! At least have a conservative base map that have boost control or you will throw a CEL. With any boosted honda you will want some sort of tune whether is street/dyno to get a/f ratio correct so your honda doesn't go boom esp with 12psi on no tune. but as far as your power I would estimate that you will make somewhere in the 250 - 275 range on an "ok" tune.
Old Oct 11, 2008 | 06:54 PM
tunerboy90's Avatar
Default Re: b18b1 turbo questions (Jayman_Gsr)
ok so you are saying that i need a tune...
what is a good program and how should i tune it...
are there any websites that will send you a programmed ecu according to what your setup is
Old Oct 11, 2008 | 07:03 PM
Jayman_Gsr's Avatar
What computer are you using? I will be running a P06 (civic dx) (chipped, vtec, IAB, Hondalog) I have the free version of crome (tunewithcrome.com free download) and buy a moates burn2 (I have the new burn2 $85) and a wideband go hit the street log the sensors and reburn the chip until everything is up to your spec...
If you don't want to blow the car just load a conservitive basemap.....(just add boost to the rom and plenty of fuel and about 1 - .75 degrees of timing with 110% turbo efficiency for a good start...*this is for crome
just search the net you can find loads of info! You DO NOT want a website to tune the chip you will be better off street tuning yourself these best "guess" chips are probably have a good basemap but if you do the above you will have a better map for YOUR setup...
Get your chipping kit and rom burner from many sites but I got mine for xenocron.com check it out along with tunewithcrome.com ;D
Old Oct 11, 2008 | 07:40 PM
Dave_Dc2's Avatar
My Friend has the <U></U>same<U></U> exact set up, except only on 10 ,12 would be pushing it i would only do ten and u definatly should get it tuned. he got 230whp with a good tune and only 10lbs and smashes all over a bunch of cars
Old Oct 11, 2008 | 08:59 PM
tunerboy90's Avatar
Default Re: b18b1 turbo questions (Dave_Dc2)
remind you guys i will be running the stock obd0 pr4 ecu and i dont want to convert to obd1...will i run in2 tuning problems with my obd0 ecu?
Old Oct 12, 2008 | 07:22 PM
Jayman_Gsr's Avatar
No you would have to use an OBD0 tuning program such as turboedit...but I don't know if its free just search on the net to find everything you need to know Plus chipping that comp and youll be set
hillssol95
Nov 19, 2010 02:54 AM
gosu08
Mar 2, 2008 03:38 AM
allanonjj
Jun 7, 2005 05:11 PM
1.8t
Dec 21, 2003 04:38 PM
hotsaucex2
Jun 16, 2003 02:20 AM
