ecu upgrade
Old Oct 11, 2008 | 03:38 PM
turbodelsolb16a2's Avatar
Default ecu upgrade
i have a 97 civic ex with b16a2 swap but i still have the stock ecu witch is a p2p i was looking for an upgrade.....some one told me to get a pct witch is a type-r ecu....witch one would you guys think is better?
Old Oct 11, 2008 | 03:40 PM
Kendall's Avatar
Do you have your car upgraded to the point where you need to mess with the tune?
Old Oct 11, 2008 | 03:48 PM
Default Re: (Kendall)
not really it just redlines at 75k....and vtec kicks at 6k...
Old Oct 11, 2008 | 04:15 PM
IndySporty's Avatar
Default Re: (turbodelsolb16a2)
AP2T is a 99 Civic Si computer that's the one you need, a B16. Here's an auction for one on Ebay 300265295339 item number.
Old Oct 11, 2008 | 04:23 PM
94EG8's Avatar
Seagull Management
Default Re: (IndySporty)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IndySporty &raquo;</TD></TR><TR><TD CLASS="quote">AP2T is a 99 Civic Si computer that's the one you need, a B16. Here's an auction for one on Ebay 300265295339 item number.</TD></TR></TABLE>
Not quite. The ECU the OP needs comes from a '96 - '97 Del Sol vtec due to the fact that '96 - '98 civics are OBD2a and '99 - '00 are OBD2b (the plugs are different between them, P2P will work through the use a of a jumper harness though.)
Old Oct 11, 2008 | 04:26 PM
turbojdmhatch's Avatar
Default Re: (94EG8)
i say jumper harness for obd1 and then get a p28 with a none ebay chip
choua01
Nov 20, 2008 06:55 PM
fishboy
Nov 3, 2008 03:42 PM
Break4Gold
Dec 13, 2007 08:44 PM
Civic97s
Jun 26, 2006 05:04 AM
