d15 swap out of a 95 cx 200 bucks come get it
i have a d15 out of a cx it comes with everything accept axles wire harness and plug wires it runs great tranny shifts good no grinds does burn a small amount of oil new headgasket milled head and timing belt and water pump about 1k on it since than it gets awsome gas milage i was averaging 30mpg with half city half high waay
Modified by fastboy559 at 7:48 AM 10/14/2008
u got pics send me pics to aszello@aim.com if not let me know more about it.
it was the origanal motor in my car it had about 165kon it in winter of last year i replaced the headgasket milled the head new water pump and timing belt and thermostatdailly drove it it was dead reliable never had an issue had no problems taking it on long trips does smoke a lil bit but not much it could prolly use rings but its not to bad just used about a quarter to a half of quart every oil change i did not dog this motor it only say 5k about 2 times
alright. ull bring it to me? and is the trans still attached? and r u trying to sell me something that im going to have to tear apart to fix the bearings because u spun a bearing or a rods knocking? i dont want any junk. and i dont want to get [freak]ed. u know where im coming from.
trans is still on i took it it out everything was fine it drove fine no nock or nothing just is a lil worn the only reason i pulled it is cuz i did a swap i just need it gone
i will deliver if ur near me im not going out of my way for a 100 bucks i am in crownsville and drive to elkridge everyday
i think its a po5 whatever a cx comes with im kind of firm at a 100 for a running swap is good
about an hour maybe less im good thursday if u meet me at my work wich is closer to u anyways let me no text 4434542244
coming tomorrow hopefully my brother can get up for work so i can use his truck if all goes as planed ill be heading up that way by 9 in the moring probably maybe a lil later. ill text u.
92BlackSi
Jan 2, 2006 01:53 PM
elliott6
Nov 12, 2004 09:35 AM
