Having a few problems with my Gen 3
Old Oct 11, 2008 | 12:30 AM
rockNrollteg's Avatar
Default Having a few problems with my Gen 3
Motor: b18c1 complete swap.
Car: 98 GS
I'm getting a rhythmic chatter on idle. It goes away when I press the clutch down. However, it comes back when I put it in gear and start accelerating, except it sounds faster to where it's no longer rhythmic, just constant. It goes away again when accelerating above 4 grand and comes back yet again when I let off of the gas when in gear.
During the swap, I was cheap and i used the Exedy organic clutch/pressure plate and 8lb. flywheel off of my previous LSVTEC setup (LS tranny). The only thing new was the throwout bearing. I also used the slave cylinder off the LS block if that matters. The one that came with the GSR was stuck closed.
The other problem I'm getting is a code p1337 (uber leet code). We checked it out and apparently it's "CSF sensor no signal" or "Diagnostic Trouble Code (DTC) P1337: No signal in the Crankshaft Speed Fluctuation (CKF) sensor circuit".
Any help is appreciated.
Old Oct 11, 2008 | 10:36 PM
anyone?
Old Oct 11, 2008 | 10:51 PM
vietnamezerice's Avatar
Default Re: (rockNrollteg)
what year motor is it?
Old Oct 11, 2008 | 11:44 PM
94VTECoupe's Avatar
Default Re: (vietnamezerice)
I don't know much about diagnosing clutch problems, but I did have a chatter sound in my transmission that when it would be in neutral just sitting and idling it would chatter and then when I pushed the clutch in it would go away, and it would make the noise like you said when I would drive too, but mine was a bad main shaft bearing in the tranny case (my mechanic and I narrowed it down to this). But I know there are bearings in the clutch too that might possibly cause something like this to happen, although as far as I know, I would think that if it was your clutch it would make the sound when your clutch was pushed in, not when it was out.
Old Oct 12, 2008 | 09:18 AM
Default Re: (94VTECoupe)
hm. you've got a good point there. i was thinking bearings too, but i was hoping it wouldn't be that. how much was it to replace yours?
vietnamezerice: the motor's a 96 obd2
Old Oct 12, 2008 | 10:06 AM
D_koschak's Avatar
i would prolly say your throwout bearing is junk and or the pilot bearing i had the same prob in my civic and it was a bad throwout bearing and i even put a new one on i would check that before u ripp apart the transmission
Old Oct 12, 2008 | 10:11 AM
sh4mr0ck's Avatar
Default Re: (D_koschak)
I'm having the same problem with my GSR engine. It's going to be one of three things:
Main shaft bearing or throwout bearing
or POSSIBLY a broken finger on your clutch.
Old Oct 12, 2008 | 10:26 PM
Default Re: (sh4mr0ck)
you're the 4th person i know (including me) with a gsr and this problem. seems a bit common. i guess i have a lot of exploring to do. this blows. i changed over from an lsvtec so i WOULDN'T have anymore problems. oh well.
Old Oct 12, 2008 | 11:06 PM
since you have that CEL code doesn't that mean something's wrong with your crank position sensor near the oil pump?
Old Oct 13, 2008 | 07:19 PM
yeah it's probably not wired right. the car's running fine though, but i'm guessing it's running off some other sensor to sense engine speed. i definitely need to get that figured out. time is limited
Old Oct 16, 2008 | 08:48 PM
i called acura today and they said it was the throwout bearing and pilot bearing causing the problems. i thought i might as well change the clutch and fly while i'm at it. any chance they're right??
Old Oct 16, 2008 | 09:53 PM
i think that if it's by any chance your throwout bearing, it will constantly make noise as long as you're off the clutch... i think they're just trying to make a quick buck on you... have you found out why you have the code from the CEL?
Old Oct 17, 2008 | 08:24 PM
no, not yet. i'll have time next week to check it out. i'm hoping it's just a wiring issue from the swap. by the way, it does make noise when i'm off the clutch. when i press it down, that's when it goes away, but as long as i'm off of it, it's chattering.
fuzzysig
Transmission & Drivetrain
Jul 25, 2017 10:13 PM
wgbm92
Nov 25, 2012 02:53 AM
homedude
Sep 18, 2006 06:56 AM
smeister
Nov 3, 2002 11:06 AM
fluffy
Sep 20, 2002 08:09 PM
