Removal of Flywheel
Old Jul 28, 2002 | 12:00 PM
1 speedstar's Avatar
Default Removal of Flywheel
ok, right now im in the process of taking out the flywheel(b18c). im using an extended 12pt 17mm socket and i tried taking the bolts off, but i'm scared of strippin the bolt. i'm gonna go pick up a standard 12pt 17mm and see if that helps.
if anyone has any informative information, i'd really appreciate it. thanks
Old Jul 28, 2002 | 01:59 PM
owen_the_soyboy's Avatar
Default Re: Removal of Flywheel (A-Spec)
just make sure you have a friend lock down the flywheel by lodging a screwdriver thru the starter teeth or you can mount a home made bracket to a pressure plate bolt hole and a tranny bolt hole to lock the flywheel in place.
use a breaker bar not a ratchet, that will help... 18" long works great!
give it a good tug or two and they should break loose.
good luck bro
Old Jul 28, 2002 | 05:03 PM
IlikeTODA's Avatar
Default Re: Removal of Flywheel (owen_the_soyboy)
Just keep pressure on the breaker bar towards the bolt. If it can't work its way off then it can't get stripped.
Thanks, J
jdm206
Oct 5, 2006 04:42 PM
upstatee
Sep 10, 2005 09:38 PM
BlueShadow
14
Jul 31, 2004 04:45 AM
integraautox
Dec 24, 2003 06:14 PM
jondancer
10
Apr 18, 2003 07:19 AM
