Help with my Illumina/Prokit Suspension
Old Oct 10, 2008 | 01:04 PM
BoltonGSR's Avatar
Default Help with my Illumina/Prokit Suspension
I just got some illuminas and eibach prokit. There arent much instructions...
Where do all of these little parts go? Do I need to retain anything from my stock suspension? Im trying to put these together before the install tomorrow. Which springs go on the back and on the front? How do I know if there on the shock right?
Old Oct 10, 2008 | 09:32 PM
vietnamezerice's Avatar
Default Re: Help with my Illumina/Prokit Suspension (BoltonGSR)
the metal tube goes inside both of the black rubber pieces and i believe you should put the big washer on first before you put the rubber with metal tube over the shock piston... I'd use the dust cover from the stock shocks if they fit...
Old Oct 10, 2008 | 09:33 PM
Default Re: Help with my Illumina/Prokit Suspension (vietnamezerice)
and as for which spring goes front or rear... i guess each spring has a part number just look up online or call a company and inquire with them which one's which
Old Oct 11, 2008 | 05:25 AM
sjbmx's Avatar
those pieces are going to replace the hardware for your top hats ( the things u see in you engine bay and trunk). your going to reuse your spring cover thing as well, your also gunna need a spring commpersor to take that off( u can rent them at most auto stores). the one on the left is for the front. do a search on a how to for this. oh and im not sure about these but on mine it said if i reused the dust cove it could damage the shock ( idk y). any other questions?????
Old Oct 11, 2008 | 05:55 AM
thabao's Avatar
if you ever bother to look at the little piece of paper that come with everything, it tells you what to do. reading is FUNDAMENTAL!!
Old Oct 11, 2008 | 06:38 AM
BoltonGSR's Avatar
Default Re: Help with my Illumina/Prokit Suspension (thabao)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thabao &raquo;</TD></TR><TR><TD CLASS="quote">if you ever bother to look at the little piece of paper that come with everything, it tells you what to do. reading is FUNDAMENTAL!! </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoltonGSR &raquo;</TD></TR><TR><TD CLASS="quote">I just got some illuminas and eibach prokit. There arent much instructions...</TD></TR></TABLE>
Thanks for the replies. Ill post more questions as they arise
Old Oct 11, 2008 | 02:48 PM
qazaq's Avatar
dude check the installation papers that came with shocks/springs
i installed sportlines on illuminas, same thing. both came with fairly straight forward instructions. also you can refer to oem shock assembly, same components only use tokicos bolt torque specs. thicker springs (left on your pic) goes to the front, it also has a part number on it and it should say in one of the papers that came with springs which one is which
one more thing. front shocks do not come with bump stops and dusters. i got mine from shox.com, they sell KYB dust boot+bump stop kit which fits alluminas nicely and its not really expensive. i would advise you to invest in getting those, 1kit for each shock.
Old Oct 11, 2008 | 03:08 PM
BoltonGSR's Avatar
Default Re: Help with my Illumina/Prokit Suspension (qazaq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qazaq &raquo;</TD></TR><TR><TD CLASS="quote">dude check the installation papers that came with shocks/springs
one more thing. front shocks do not come with bump stops and dusters. i got mine from shox.com, they sell KYB dust boot+bump stop kit which fits alluminas nicely and its not really expensive. i would advise you to invest in getting those, 1kit for each shock.</TD></TR></TABLE>The only thing my instructions talk about is the torque specs. Do i re use anything from the stock suspension?
Old Oct 11, 2008 | 04:47 PM
qazaq's Avatar
only top hats with flat rubber inserts. the instruction is written, read it
Old Oct 11, 2008 | 10:37 PM
maybe there's instructions online somewhere
Old Oct 16, 2008 | 09:11 AM
BoltonGSR's Avatar
What is that tan rubber piece on the right shock? Someone told me to take it off.
Old Oct 16, 2008 | 12:10 PM
TunerN00b's Avatar
Wow.
Thats the bumpstop. Leave it on there, your shocks will thank you for doing so.
Old Oct 16, 2008 | 02:12 PM
qazaq's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoltonGSR &raquo;</TD></TR><TR><TD CLASS="quote">What is that tan rubber piece on the right shock? Someone toldb me to take it off.</TD></TR></TABLE>
do not take it off, plus you will need to purchase a set for the front shocks. since they sold separately.
like i said earlier:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qazaq &raquo;</TD></TR><TR><TD CLASS="quote">one more thing. front shocks do not come with bump stops and dusters. i got mine from shox.com, they sell KYB dust boot+bump stop kit which fits alluminas nicely and its not really expensive. i would advise you to invest in getting those, 1kit for each shock. </TD></TR></TABLE>
Old Oct 16, 2008 | 06:33 PM
BoltonGSR's Avatar
</TD></TR></TABLE>What?? I thought that you used the washers off the stock shock??
Old Oct 16, 2008 | 06:41 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoltonGSR &raquo;</TD></TR><TR><TD CLASS="quote">What?? I thought that you used the washers off the stock shock??
he's not talking about any washers... he's talking about the bumpstops... read more careful dude
Old Oct 16, 2008 | 06:48 PM
BoltonGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietnamezerice &raquo;</TD></TR><TR><TD CLASS="quote">
he's not talking about any washers... he's talking about the bumpstops... read more careful dude </TD></TR></TABLE>I know that. But i thought that the kit was ready to install with everything transferred over from the stock suspension.
Old Oct 16, 2008 | 06:50 PM
apparently they do not come with a complete set of bump stops... I guess you can still put them on... but it's a good way to bottom out on your new shocks
Old Oct 16, 2008 | 07:23 PM
BoltonGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietnamezerice &raquo;</TD></TR><TR><TD CLASS="quote">apparently they do not come with a complete set of bump stops... I guess you can still put them on... but it's a good way to bottom out on your new shocks </TD></TR></TABLE>Wow, seriously tokico? 450 dollars for some shocks and they can only provide two bumpstops?
Im really confused now cause all i saw on my stock shocks was a washer, i dont remember seeing any bump stop like it shows here...number 12
Old Oct 16, 2008 | 08:25 PM
hpimichael02's Avatar
off subject a little bit but didnt want to start a new thread , but how much would a shop charge to put a set of these coilovers in ?&gt;?
Old Oct 16, 2008 | 08:39 PM
Default Re: (hpimichael02)
hmmm I'm gonna say it's 2-3 hour job for an integra... shop rates are anywhere from 60-90...
Old Oct 17, 2008 | 07:02 AM
BoltonGSR's Avatar
Default Re: (vietnamezerice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alphalanos &raquo;</TD></TR><TR><TD CLASS="quote">
here you go
</TD></TR></TABLE>Ok, im really confused. Number 12 on the list here. I did NOT have any of those bumpstops on my stocks shocks. They have never been tampered with before. I checked inside the dust shield and nothing on BOTH front shocks.
Please tell me i can pick up some from a parts store like autozone...
Modified by BoltonGSR at 12:02 PM 10/17/2008
Old Oct 17, 2008 | 02:32 PM
qazaq's Avatar
Default Re: (BoltonGSR)
jeez.. you probably still never refereed to installation instructions that came with illuminas. it says you need to reuse your stock bump stops, but if they are in poor condition it voids the warranty. i know it sucks spending that much money and not get complete kit, but this is the way it comes. if you do not want to look into reading the instructions you can at least take you time and read posts thoroughly.
i went through installing the same set up and im telling you exactly what you need. purchase 2 boot/bump stop kits; as far as i remember it cost me around $20 shipped from shox.com, you need to call them tho. you can also purchase bump stop at the dealer but it will cost you more and those do not come with the dust boot.
You need:
-Illuminas kit
-Springs
-2 bump stop/boot kits (for front shocks, i think mine were H&R)
-2 dust boots for rear shocks (you can probably get those at local auto store)
-8 zip ties (for tightening dust boots, not supplied with the kit, 2 for each boot)
-reuse stock top hats w/ rubber seat #5, 7 on ur image
-reuse stock metal seat #11 (im pretty sure i reused it)
from Tokico website "Requries re-installation of factory Safety Washer (DC2)"
if you get the same bump stop kit it will also have few more washers which you will not need so don't worry about those, you don't need them
also you will not need to use part #10, it should not fit. at least mine didn't. for assembly just follow up the diagram from the image u posted. use torque specs supplied with illuminas.
this project should be as easy as changing oil, only if wont have any problems with rusted old bolts when taking old suspension off. when you install everything back, make sure you tighten the bolts when your car is at the riding height.
get it done the right way. take your time, do not rush and you should be fine. gl
Old Oct 17, 2008 | 04:04 PM
SoTexDC2's Avatar
Default Re: (qazaq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qazaq &raquo;</TD></TR><TR><TD CLASS="quote">jeez.. you probably still never refereed to installation instructions that came with illuminas. if you do not want to look into reading the instructions you can at least take you time and read posts thoroughly.
This information has been spoon fed to him in this thread, and the identical post in the suspension forum.
https://honda-tech.com/zerothread?id=2406061
He ignores my advice, he is making this 19098 times harder than it needs to be.
Old Oct 17, 2008 | 05:31 PM
qazaq's Avatar
Default Re: (SoTexDC2)
Old Oct 17, 2008 | 06:15 PM
BoltonGSR's Avatar
Default Re: (qazaq)
Wow, now that is what im talking about. Thanks a lot for your patience.
What size allen key do i need to tighten the tociko shock?
ericrcan
May 13, 2012 07:26 PM
mjf6866
Feb 18, 2012 09:42 PM
nomoshing
Jul 3, 2008 08:46 AM
skercr0w
Suspension & Brakes
Nov 19, 2005 01:22 AM
