horn clicks?
Old Oct 9, 2008 | 09:12 PM
k7q's Avatar
k7q
Default horn clicks?
i have a hub, aftermarket steering wheel and the horn stops working
i wired it up like this
http://weaksauceforums.org/viewtopic.php?t=2549
work good till i pulled my motor and now it stops working.
fuse is ok. horn works. ( i wire the horn straight to the battery to see if it works and it does )
every time i hit the horn button and i can hear a click. do i have a bad relay? or bad horn?>
Old Oct 9, 2008 | 09:59 PM
Former User's Avatar
Default Re: horn clicks? (k7q)
The problem is almost definitely due to bad horn switch wiring in the steering wheel. Double check your work.
KateBeck
Sep 11, 2014 10:48 AM
zue1nia
10
Jul 6, 2013 11:06 AM
jmeyer99
Apr 28, 2010 02:13 PM
excivicboy96
May 25, 2006 09:38 PM
LB CRX
Nov 24, 2002 11:31 PM
