B16A build: eagle crank hitting oil squirters
Old Oct 9, 2008 | 08:12 PM
EF_EJB16A's Avatar
Default B16A build: eagle crank hitting oil squirters
i bought the Eagle rotating assembly for a B16 and i was [freak]InG stupid and i got it balanced before test fitting. i just threw everything together and my block wouldn't turn. i tore it apart and my oil squirters are hitting the crank. one is bent im not sure if i was sent a LS or GSR crank by mistake or what. do i need to knife edge the crank ? if i do that theres another 125 bucks down the drain to balance it. and then if that doesn't work i will need to spend another 125 to balance the stock
one
Old Oct 9, 2008 | 08:19 PM
fourthgenhatchB17's Avatar
Default Re: B16A build: eagle crank hitting oil squirters (EF_EJB16A)
Pull the squirters and plug the holes. There is a company that sells plugs. Do a google search.
Old Oct 9, 2008 | 09:57 PM
projectTeG's Avatar
plug them! golden eagle makes a kit.
Old Oct 10, 2008 | 02:57 AM
patriot's Avatar
Default Re: (projectTeG)
Yeah, if you had asked before hand Eagle wouldve told you that you needed to get rid of them. It's no big deal. If you have some extra rod bolts lying around they'll work. Just seat them in with some red loctite and cut them flush with the block.
Old Oct 10, 2008 | 09:25 AM
CerealKiller's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">plug them! golden eagle makes a kit.</TD></TR></TABLE>
x2
Old Oct 11, 2008 | 08:07 PM
EF_EJB16A's Avatar
i thought about blocking them off but that doesn't seem like a good idea, isn't that to keep the cylinder walls cool? i called eagle and the dumb *** told me just to bend them i did and i snapped the [freak]ing bastard at the base.
Old Oct 11, 2008 | 08:27 PM
Phil M's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_EJB16A &raquo;</TD></TR><TR><TD CLASS="quote">i thought about blocking them off but that doesn't seem like a good idea, isn't that to keep the cylinder walls cool? i called eagle and the dumb *** told me just to bend them i did and i snapped the [freak]ing bastard at the base. </TD></TR></TABLE>
No that is what your cooling system is for. They were originally meant to cool the pistons. You won't really need them with aftermarket pistons. I would keep them if you are going turbo, but just close them up as suggested.
Also, when you bend them, you are supposed to heat them up with a torch so they are "flexible" of sorts.
Garrett
Nov 14, 2008 06:24 PM
slo4now
Jun 11, 2007 10:23 AM
K20 EG
Jun 23, 2003 03:48 PM
-16V-
Nov 11, 2002 05:35 PM
DA tegger
Jan 21, 2002 10:53 AM
