Gsr crank in B16 block
well for one, what year GSR crank are you asking about 92-932 GSR/1.7L or 94-00 GSR/1.8L?
the 1.7L crank will drop right into a B16A block, but you'll need B17A rods as well in order for all to work like butta.
the 1.8L crank on the otherhand, is not a drop-in-and-go application. Machining needs to be done since the P72 crank's journal's are a smaller width than a B16A & B17A's crank+rod journals.....and not to mention, you'd tottally need custom rods & possibly pistons to make it all work (some aftermarket rods don't accept an OEM piston, or do but need mod'ing). The $$$ adds up and quite frankly is not worth doing IMO. And yes, the rod ratio would suck major kitty litter.
The reason im asking is cause i been sitting on this b-16 block for a while ..
to givve you an idea how long
it was one of the first to receive Sleeves @ 84mm from Dan Benson a lonnnggg time ago
i dont want to let it go to waste like my Revhard hard custom. turbo kit sitting around collecting dust
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20---Vtec »</TD></TR><TR><TD CLASS="quote">how about the 94-00 gsr crank ??
thanks for the valuable info</TD></TR></TABLE>
retype:
retype:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20---Vtec »</TD></TR><TR><TD CLASS="quote">gotcha...
i just got a line on a b17 crank.
i will just do that and let it alone</TD></TR></TABLE>
good idea.... 1.7L ownz j00!
oh yeah, make sure you get the 1.7L rods too....their hard to find as stand alones.
TimKennard
Apr 27, 2013 12:15 PM
white4doorsi
Mar 15, 2008 05:35 PM
