oil leak problem!!
Old Oct 9, 2008 | 07:40 PM
dc2beast978's Avatar
Default oil leak problem!!
well guys i got a leak between the block n tranmission soo i change the rear main seal well it still leaking from the same spot...and also change the oil pan gasket also the longblock is clean no oil leak from anywhere but where the block n trannmission meet.. soo idk what it is soo guys any problems like mines or any advance or help plzzz guys
Old Oct 9, 2008 | 07:48 PM
mistik_DC4's Avatar
Default Re: oil leak problem!! (dc2beast978)
Same with mines. Help please?
Old Oct 9, 2008 | 07:55 PM
Default Re: oil leak problem!! (mistik_DC4)
man we both on the same page (mistik dc4) i change the seal put back the tranny turn thr bitch on still leak i dont kno man
Old Oct 9, 2008 | 07:58 PM
mistik_DC4's Avatar
Are u talking about the axle seal?
Old Oct 9, 2008 | 08:01 PM
no the rear main seal **** u think it could b the axle seal?? leakin from the bottom of the tranny where the block meet
ruffrhyder's Avatar
You may have a scratch on your crank or rear main seal housing, that's why it's still leaking after replacing the seal.
Old Oct 9, 2008 | 08:13 PM
mistik_DC4's Avatar
Default Re: oil leak problem!! (ruffrhyder)
Where's the main seal.? Picture?
Old Oct 9, 2008 | 08:16 PM
ruffrhyder's Avatar
#27 in link
http://www.hondapartsunlimited...dIrno=
Old Oct 9, 2008 | 08:22 PM
mistik_DC4's Avatar
That's the main seal on the block? Thanks !
Old Oct 10, 2008 | 09:56 PM
okk u think i should replace the rear main seal housing to see if that works
Old Oct 10, 2008 | 09:59 PM
ruffrhyder's Avatar
When you replaced the rear main seal, did you measure how far the original seal was protruding from the housing before you removed it, and did you make sure you pressed the new seal in the same amount as the original seal?
How did you press the new seal in?
Old Oct 11, 2008 | 10:04 AM
yes did everything correct the seal went in tight fit perfect the thing is when i took of the tranny again the main seal wasent moist or wet it was good but still leak from there
markiebizzle
Mar 8, 2006 07:45 AM
LSVTEC 91 Civic
Apr 26, 2005 04:23 AM
locoSIR20
Apr 10, 2005 12:30 PM
B16CRXT
May 12, 2004 11:58 AM
BigIslandBoi
Sep 19, 2003 12:16 AM
