A/F Ratio
Old Oct 9, 2008 | 01:49 PM
kenbo21's Avatar
Default A/F Ratio
I got 2004 civic ex...Turbo'd with t3/t4...just installed Aem UEGO and I am wondering what is an ok range to be at once I get it fully tuned with FIC
Right now car is tuned with Apexi Neo.......
At Idle its around 10.5-11.4
and when hit the gas around 13.4-14.5
What will be a good range to make sure my car is running fine and not to rich after my tune...I have heard the person that is tuning my car sometimes runs it a little rich...Well I want to make sure this doesn't happen....
Old Oct 11, 2008 | 07:44 AM
skipbarber's Avatar
this is a fairly basic question with a pretty technical explanation.
First and foremost, you have to understand the differences between open and closed loop engine operation. Since most of the time you run in closed loop, you need to pay close attention to partial and full throttle boosting. Your stock ECU is aiming for 14.7 AFR at all times, during closed loop operation it is constantly going between +1 and -1 from 14.7. This is done so that the ECU can constantly monitor the catalytic converters operation. During WOT, however, the ECU will kick back to open loop, and this is where your tuning device can actually do its job. I personally refuse to let my AFR go above 12 AFR under ANY boost. For some people, this is actually TOO lean. Performance oriented individuals who use boost heavily (i only use it when i need it, in short bursts, i dont lay on it) usually aim between 10-11, sometimes lower. But you can say good bye to your o2 and AFR sensors in short time, along with any existing fuel economy you might have.
Your tuner should know what to do, so im not sure what youre worried about. your idle is way too rich and on throttle you're pretty lean. your numbers should be the other way around, unless youre looking at on-throttle numbers without the engine being loaded. Theres plenty of info on this available all over the net. Your setup is going to affect your numbers, as is any ignition adjustments your tuner will make.
hope this helps..
Old Oct 11, 2008 | 10:23 PM
pwrofdrm's Avatar
Default Re: A/F Ratio (kenbo21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kenbo21 &raquo;</TD></TR><TR><TD CLASS="quote">ALRIGHT THANKS FOR THE HELP......!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
NOT</TD></TR></TABLE>
One of the reasons no one posted is because this information is easily available by searching through the Forced Induction FAQ, or even the Tuning forum FAQ.
But to answer your question here because I'm a nice guy, your idle AFR should hover around 14.7, partial throttle should be around there too, and full throttle in boost should be no higher than 12.
So basically, your tune sucks, get to someone who can tune that thing quick before you blow your **** up
Old Oct 12, 2008 | 01:05 AM
Glove's Avatar
Default Re: A/F Ratio (pwrofdrm)
anything lower than 11.0 is totally unnessesary,
from 1-5 psi i usually try to hit around 12.5 ish
then 5-10 i go 11.8 ish
then 10 and after i try to hit 11.4, 11.5 ish
lets say your going up hill, and you car is only making 1 pound of boost, seriously, if its at like 11 or 10, thats useless and wasting gas. your tuner should be able to check for ping while tuning. to see whats the best afr's to use for your car.
the leaner you can get your afr's without it pinging, the more power you will make.
Old Oct 12, 2008 | 01:13 AM
jDMJeRk's Avatar
Default Re: A/F Ratio (Glove)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Glove &raquo;</TD></TR><TR><TD CLASS="quote">anything lower than 11.0 is totally unnessesary,
the leaner you can get your afr's without it pinging, the more power you will make.</TD></TR></TABLE>
This isn't always true. And besides why not be safe then sorry?!
I'd rather make 300hp at 11:1 A/F vs. 325hp at 12.3:1 A/F
Old Oct 12, 2008 | 01:18 AM
Glove's Avatar
Default Re: A/F Ratio (jDMJeRk)
your not gonna make 300 horses on 5 psi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jDMJeRk &raquo;</TD></TR><TR><TD CLASS="quote">
I'd rather make 300hp at 11:1 A/F vs. 325hp at 12.3:1 A/F</TD></TR></TABLE>
Old Oct 12, 2008 | 01:36 AM
jDMJeRk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Glove &raquo;</TD></TR><TR><TD CLASS="quote">your not gonna make 300 horses on 5 psi
I was using that only as an example but if you want to get technical its very possible to make 300hp on 5psi. Hell, we made over 1000 on 9psi and pump gas.
But thanks for cleaning that up for us.
Old Oct 12, 2008 | 02:36 AM
Turbo Gav's Avatar
Its all about the flow not the pressure thought we had this one put to bed on here.
I personally would rather make 312.5 @ 11.8-11.9 AFR and be about right IMO not drown it but not push it either.
11.1 we are not tuning Subaru's here
Old Oct 12, 2008 | 06:21 AM
90lsvcrxva's Avatar
Default Re: A/F Ratio (Turbo Gav)
mines 10.8 full boost. Little rich but I was extremly happy with it and perfered it alittle rich over leaning out. but thats how I wanted it. I think 11.5 to 11.8 is where u wanna be boosted
Corksil
23
Jul 14, 2011 05:59 PM
zerotorquecrix
Jan 3, 2011 12:57 PM
Rob91DA
Engine Management and Tuning
Dec 6, 2008 07:26 PM
blackeg
Apr 22, 2005 10:36 AM
7rrivera7
May 30, 2003 04:26 AM
